yamadoc643
Had trouble with my machine running in hard snow conditions. Contacted Yamaha Canada but had very poor service. They tell my they don't make an aux cooler for the attak. Have heard they work well on the apex. Need help to find an aftermarket cooler. Any suggestions?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Pioneer performance listed,but i think the attak was alot more than the small one for the apex,the apex one was like 57 bucks and the attak like 150 bucks,but give them a call.yamadoc643 said:Had trouble with my machine running in hard snow conditions. Contacted Yamaha Canada but had very poor service. They tell my they don't make an aux cooler for the attak. Have heard they work well on the apex. Need help to find an aftermarket cooler. Any suggestions?
yamadoc643
Do you have a number for Pioneer performance ?
Iceman57
http://www.pioneerperformance.net/
P-E101 Viper Rear Heat Exchanger $79.95
P-E102 4 Stroke 121" & 144" Track $57.95
P-E103 4 Stroke 136" & 151" Track $117.95
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
716-496-8800 ask for bruce.yamadoc643 said:Do you have a number for Pioneer performance ?
SledFreak
- Feb 7, 2005
- Ontario. Canada
I thought Yamaha made one for the Attack and Apex?
trenchdigger3
I think some people where using the heat exchanger from the yamaha vector on there apex last year not sure if it works on the attak ,part# is 8et-rhecr-kt ,was going to try one on my apex because I had some issues with overheating on real cold mornings when the trail was real hard,but I decided to just drain the straight antifreeze out of it and refill with a 50/50 mix and added some water wetter and see if that works if not I will be adding the heat exchanger.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Apex/RX-1/Nytro/RS Vector All 121" models and also 144" models:
Yamaha Part Number: 8ET-RHECR-KT-00
Price: $35.20
Attak/Warrior/Rage All 136" and 151" models:
Yamaha Part Number: 8EP-RHECR-KT-00
Price: $71.64
***Pricing is from Port Yamaha, call Kevin and order yours today!!***
www.portyamaha.com
Price: $35.20
Price: $71.64
www.portyamaha.com
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Allen, the larger cooler needed added protection from studs, does the same hold true for the smaller one for the Apex?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Dan, the 136 needs protectors with it when running studs, but from my experience the 121 cooler does not. It mainly sits back against the rear flap/aluminum end cap in the tunnel so I don't believe it would need one.
trenchdigger3 said:I think some people where using the heat exchanger from the yamaha vector on there apex last year not sure if it works on the attak ,part# is 8et-rhecr-kt ,was going to try one on my apex because I had some issues with overheating on real cold mornings when the trail was real hard,but I decided to just drain the straight antifreeze out of it and refill with a 50/50 mix and added some water wetter and see if that works if not I will be adding the heat exchanger.
I'd do this or like my machine has ENGINE ICE
yamadoc643
thanks for the info. I will do some calling around to make sure fit between the tunnel protectors. Also just curious if many people have this trouble with attak/apex running hot.
70superbee
Attak rear cooler
Not to sound dumb but where do the guards go for the aux. cooler. I have the kit for my attak. It says nothing about studs, in the directions.
Thanks Rich
Thanks Rich
70superbee
Attak rear cooler
Thanks Rich
Thanks Rich
LazyBastard
You have to fabricate the protector yourself. Use common sense to extend the existing tunnel protectors.
