Firecatdude
- Dec 26, 2020
- NW Ontario
- 2017 ZR 9000 LTD
So I was cleaning up the sled for summer storage and noticed that is appears the rivets under the gas tank by the exhaust are loose and possibly rubbing through the tunnel. I think these rivets would be for the heat exchanger. There is one on each side and they both look the same. Has anyone else found this? Thanks
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Tunnel Dammage Due to Ice
Noticed i have damage at the front of my tunnel along the top row of louvres. Must be due to ice build up coming around and compressing at the front of the tunnel. Saw a post on here months ago about someone posting the same with the front/top of the tunnel and louvres damaged. Wanted to see...
stgdz
- Mar 27, 2021
- Buffalo MN
Imho this motor chassis combination, especially tuned just tries to kill itself.
You really need to go through all the chassis and suspension bolts every spring and retorque everything as they will loosen/stretch.
I had both side spars, henid the tcl on pto side and what turbo is mounted to in exhaust have loose bolts. Going through the rest I found two chanincase to tunnel bolts (by sight glass) loose. Lower A-arms to chassis was loose
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Yes common issue.. There are actually 4 rivets, you need to remove the tank and header to fix this issue.. has nothing to do with being tuned, after first season and 3100k mine were all loose and my sled was stock.So I was cleaning up the sled for summer storage and noticed that is appears the rivets under the gas tank by the exhaust are loose and possibly rubbing through the tunnel. I think these rivets would be for the heat exchanger. There is one on each side and they both look the same. Has anyone else found this? Thanks
beanie
- Jun 11, 2005
very common . Mine separated and some one on this site sold me a support plate and was added to the ton of the tunnel . pretty thin material there . Lots of work .So I was cleaning up the sled for summer storage and noticed that is appears the rivets under the gas tank by the exhaust are loose and possibly rubbing through the tunnel. I think these rivets would be for the heat exchanger. There is one on each side and they both look the same. Has anyone else found this? Thanks
sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
Is this Rivnut repair?
beanie
- Jun 11, 2005
no , You need good rivets most likely with large heads and washers . My holes and rivets were holding nothingIs this Rivnut repair?
beanie
- Jun 11, 2005
Search this site for fixes if the supplier of the plates is still here ?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Turboflash
- Mar 18, 2019
- Southern MN
Material is thin and ice buildup/ice being pulled onto track drive is really hard on those little rivets. Common to see most/all loose and pulled through outer alum skin. Need reinforcement plates. Absent that, add another 2-4 rivets spaced out in-between what is there. Use structural rivets, highest strength ones you can find.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
It's all in the link I posted on post number 2 here.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
And it is also a sticky posted at the top of sidewinder section sidewinder problems and fixes.
stgdz
- Mar 27, 2021
- Buffalo MN
How will structural rivets benefit from not ripping through the tunnel. Yeah they will hold it tighter but that skin is thin.Material is thin and ice buildup/ice being pulled onto track drive is really hard on those little rivets. Common to see most/all loose and pulled through outer alum skin. Need reinforcement plates. Absent that, add another 2-4 rivets spaced out in-between what is there. Use structural rivets, highest strength ones you can find.
The idea of adding more rivets will probably work better.
sab2022
- Feb 21, 2020
- Maine
More rivets means more holes (more stress cracks). if its thin IMO you have to address that problem first and use a doubler plate if there room and then afix the doubler plate to that thin area with SS rivets or nylon nuts. That what I would try to do. Good Luck
"A doubler plate refers to a small piece of plate that is attached to a larger area, to provide strengthening in that location. In engineering, it is common to refer to it simply as “doubler.”
Turboflash
- Mar 18, 2019
- Southern MN
Just that I've seen most sleds w loose rivets. At least structural ones don't come loose. I add more to try increase overall strength. Not seen more rivets causing stress cracks. Best permanent fix is doubler plates but it's allot more work cuz to do it right, you need to remove track drive shaft with all that entails.How will structural rivets benefit from not ripping through the tunnel. Yeah they will hold it tighter but that skin is thin.
