yamyfreak
Anybody have this happen yet. Was out today and left my last stop and started the Viper dash was working, then plugged in the visor plug and dash went dead. Visor power also dead. Sled ran good but no power to the dash. ?????
yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
Sounds like you blew a fuse
FAMILYMAN
x2yamahabuyer said:Sounds like you blew a fuse
pooner
Probably a short in your cord. You also lost your tail light. Just heads up.
canadianhunter
On mine the hood has to come off to get to the fuse box.
Another reason I ran a 10 amp. fuse at battery, wire to handle bar riser and 2nd 5 amp. fuse to shield cord. Plus another 5amp. to a 12 V plug so my GPS has power at all times.
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
You also lost reverse the fuse you blew is in the fuse box on the left side behind the coolant bottle you have to take the hood loose to get to it
yamyfreak
Thanks for the info guys. Will check as soon as I get the time.
yamyfreak
They don't make it easy anymore.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I did this and it turned out being the taillight fuse. It happened cause my shield plug came apart in the power outlet and caused a short. Hood screws need to come out but you can just move hood over without taking all the way off to get at fuses.
- 10K
