basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I’m going to remove oil side panels on both my winder and viper, has anyone used the plastic push pins to reinstall the panels like what use to be used for the nytros?? I wanna go that route but don’t know what size pins to order
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Many here (including myself) have installed rivnuts in the chassis after panel removal. Then you reattach the panel with screws that thread into the rivnuts. This works great and allows you to remove the panels easily when desired. A more permanent solution vs push pins.
sideshowBob
I also would recommend the rivnut approach...works great.
Nice bling!Many here (including myself) have installed rivnuts in the chassis after panel removal. Then you reattach the panel with screws that thread into the rivnuts. This works great and allows you to remove the panels easily when desired. A more permanent solution vs push pins.View attachment 174855
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I have used plastic push pins, but not the ones from a Nytro, I use the ones found commonly on many ATV & UTV models. Drill the holes out and install them, works great. I've also installed the rivnuts as well (just did them on a 2024 model). Both work very well.
https://www.amazon.com/Motorcycle-Hardware-2005-ORRIV-Nylon-Rivet/dp/B00HMZEXO0These are the push pins I use
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Serves two purposes... A) I can easily tell which screws to remove to get my panels off, and B) bling.Nice bling!
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Thanks for the quick responses guys. I did my research before i posted this, i didnt like the rivnut idea, as of now, just for the fact Ive never dealt with them and the fact if you dont do it properly they will spin. ive dealt with them push pins for years. yeah they break once in awhile but they plastic so no big deal pop out, slap in a new one. Allen, do you remember what size drill bit you used for them push pins?
- Apr 17, 2003
- Menno, SD
- Menno, SD
The pins measure about 0.326" in size, I think 11/32 drill bit if I remember correctly.
I use those Honda ATV style push rivets also, but I find they work best when I drill the hole about 7.5mm, even though they are specified at 8mm.
- 47K
