Lowering the 2025
1049triple
Pohenegamook, Qc
Canada
2025 SRX
2018 High Country 9000
2001 SRX 700
I feel my 2025 SRX ride height is too high. As I am a light rider, I am not able to compress the suspension a lot when sitting on the machine.
Do someone have lowered their machine and what springs or other parts number did you got?
I have a set of SRX torsion springs from an earlier SRX if you are interested. Your 2025 came with the same torsion springs as all of the other LTX models, not the lowered ones like they used to have. They have a higher spring rate but less preload. I tried them on my 17 LTX SE but ended up putting a set of 15 Viper LTX torsion springs on it because I was bottoming out too easy on big bumps (whooped out trails around Grand Marais/Munising, MI). The Viper springs have the same rate but more preload.
I just saw that you are in Canada. Might not make sense to buy mine then since shipping would likely be pretty expensive. I am in Michigan
