Missing track clips....replace??
I have to second Blue Dave, since my Yamaha EX440 (1980-1983) I have not lost another track clip.
I know I have posted on this topic in the past...
I have an '06 Attak that lost a handful of clips everytime I rode. My wife's sled has similar track (camoplast 1" lug, clipped every third window) but on a Polaris. Sleds rode the same conditions. Polaris track clips are like new....
Before last season, I replaced all clips on the Attak and bolted the black rail caps solid. 2500 miles last winter, never lost one........
That must be it. I have always secured the rail cap before every season, and changed it when needed.
This is all great info and I really appreciate it. :Rockon:
I am going to the Big East snowmobile show in Oct. and I will get the tool to attach the clip there. My question is, if I just tell a salesperson that its a Ripsaw track on a 06 Attak, will they know what clips I need??
Also, I'll tighten up the rail caps. Do I have to remove the skid? I wouldn't think so.
7 clips in over 6000 miles, not bad. Also on second or third set of hyfax...not bad!
:rocks:
Ive done the track clip replacment on my old track at 4000 miles.. it will make it last..
But here is the thing.. you can get a new track for $300-350... so why not just get a new track.. and not take chances of the track itself breaking..
welter/new track
Because new clips are under $100, and you would have to stud the new track, assuming you have studs. Why fix what ain't broke.
Any tips for securing the end caps?? I just took the sled out of storage and the caps are really loose.
Thanks....
Thanks....
Back on the first page is what I did. So far about 3000 miles and still tight as the day I put them on.
LJ 452 said:
Thanks....
you have anymore of those clips??????
Below is the rail tip mod I did. It's a piece of 1mm galv. steel bent to a C-channel then drilled, I put these on both sides of the cap to reinforce it. Then used a 10mm socket head cap and a nylock nut to fasten it down. Over 4000 miles and still tight and without losing a clip since.
LJ 452, at the end of last year I lost some clips and am going to be inspecting my rail caps since I will be up by my sled this weekend. I am trying to picture what you did to yours, can't really tell by looking at your picture. Can you break it down into lame man terms for me? I don't know what you mean by the steel is bent to a c channel and then drilled. Also I cannot picture the rest of what you describe, so again if you could re describe it for me, I would very much appreciate it. thanks
sj said:
LJ 452 said:
Thanks....
It's a piece of sheet metal that I broke into a C-Channel. I've got more left over if you want P.M. me with your adress and I can mail/ drop off. It's wasn't that hard to make so if anyone else is interested let me know. Basically cut it to fit, drill a hole through both sides and get a 10mm S.H.C.S. with a nyloc nut. As I said, so far so good.
THKSNOW said:
ahicks said:
As far as the track clips requiring replacement, wether that's "normal" or not, I've been riding in Mich. for just about forever (37 years) and can honestly say I've never replaced a track clip. Tracks yes, but never a clip. Track clip wear is not normal....
I agree - but only if you're in and out of the "Virgin Snow" as you ride. If you're on hard pack or low snow conditions, you can fry hi-fax and clips in a hurry, some riders don't have a clue and don't pay any attention and ride like they rented it...
What he said!
What he said!
