Hammertime
Is this oil ok in my Attak? Thanks.
Todd
Todd
sleddheadd
As long as the API specs meet the manufacturers recomendation you are good to go.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Read this if you haven't already, especially the bitog thread attachment.
http://www.ty4stroke.com/viewtopic.php?t=89241
mr.pitstop
Lots of guys use mobil 1. You should be fine with it.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
I've been using Mobil 1 0W30 in my 06 Attak since 500 miles. Now at 8,639 and no problems. I change the oil and filter every spring after riding is over.
gun nut
16,000 miles change filter every 2 years. Mobil one.
kinger
If your engine does fail how will you know if the oil had any effect?
gun nut
kinger,
good question
good question
sleddheadd
You send the oil out fo an analysis. That will tell you if your API rating is still within tollerances or if your oil fails and was basically just working like water. it costs around $20 by an independant lab and it can tell you everything about your oil. I send both of my sleds oils in every year for annalysis. This is how you hear of people going 200,000 miles on vehicle oil changes. If the oil is holding up there is no need for changing it.kinger said:If your engine does fail how will you know if the oil had any effect?
