tomanytoyz
i have 4000+ mi on mine and its BARELY wore,maybe my wheels up top are BIGGER?
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
One of the feller's at Yamalaugh told me it is because of two things, my studs, and my track is TOO loose.
I wonder if he's ever ridden a sled?
wigyami
wear
He should have said poor design. I see the 09's have a little oval piece welded on top of the rear arm.
87gtNOS said:One of the feller's at Yamalaugh told me it is because of two things, my studs, and my track is TOO loose.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I bought the Ulmer kit pictured above but I have not put very many miles on it yet. I have heard that the bearings will not last very long if you have studs in the center of the track like I do.
Does anybody have any feedback on how long the bearings in the Ulmer kit should last with stud heads running over them. I run a fairly loose track and right now I am planning on replacing them yearly.
KevinS
woolyviper said:Ulmer has a kit that prevents this
From the first post it sounds like he is already running the Ulmer kit.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
That is exactly why I am asking if anyone has put extensive miles on the Ulmer kit with studs in the center of the track to find out how the bearings hold up.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
2500 miles and I have very slight wear. Need to stay on the gas all the time..this keeps the top in tension and away from the eye...lol.
wigyami
KevinS said:woolyviper said:Ulmer has a kit that prevents this
I read that ,but it did not look like it from the pics. Maybe he did then removed it after it fell apart
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Well, I have my Ulmer kit installed so I guess I will just have to wait and see how long the bearings last with my center stud heads hitting them.
87gtNOS
- Nov 30, 2005
- Toronto
Blue Dave said:That is exactly why I am asking if anyone has put extensive miles on the Ulmer kit with studs in the center of the track to find out how the bearings hold up.
Yes, I have the Ulmer kit. It is removed for the pics. The bearings got smashed. Only the center of the bearings were left. Actually, that was mid winter last winter. The other day when I removed the skid, the NUT and one bearing (just the center piece!!) were missing!! This sucks, because I had a couple more bearings to put on it. But now I don't have that brass bushing for both sides.
I like rehm70's setup!
How's this for Yamaha? The DEALER installed my studs!!!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Apparently Yamaha has added wear pads on the '09's that unfortunately is not a direct bolt on for the older sleds.
I also like Rehm's set-up and I will probably switch to something like that once my Ulmer kit fails. How many miles did your Ulmer kit last?
Iceman57
Blue Dave said:I bought the Ulmer kit pictured above but I have not put very many miles on it yet. I have heard that the bearings will not last very long if you have studs in the center of the track like I do.
I have had Ulmers Kit since they came out with it. I think midway through the 06 season and I have put 2500 miles on since then and the bearings are still fine. When I installed the kit there wasn’t any wear on the shock I just did so as a precautionary measure. I am studded in the center with 168 Woodys Mega Bites and I ride my sled like I stole it. I wonder why not everyone is having this problem. I wonder if it has anything to do with the limiter strap and transfer rod adjustments. I have my limiter strap moved up one hole and my transfer rod between half and minimum.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
I have not changed my limiter strap and I run at full transfer (I like to do wheelies). After the first season of about 1800 miles my shock eye was slightly worn but nowhere near as bad as the above pictures.
I installed Ulmers kit this year and I only have about 200 miles on it so far. I guess that I will just keep an eye on it. (no pun intended)
