I have customers that are wearing out bushings and ripping the adjuster boots.
How many of you are having these issues with you Monoshock skids?
cobalt650
I've got both issues. Will be taking to a dealer soon.
racer7x
My dealer says that Yamaha says there are no issues with the bushings.... LOL
GreenMtnRx1
The bushings in mine are all wore out I am waiting for the maxximum performance bushing kit to be released that has a more durable plastic.
NH Rider
- Feb 19, 2005
For what it's worth Yamaha had a TSB come out a bit ago. Any '05 RX1 is covered: Basically it's a different cable and a protector shield. We saw a few cables pull off the mono shocks last year. Ask your dealer about TSB S2005-008
Kevin
Kevin
BIG BLACK WARRIOR
I have replaced bushings, broken cable, ripped boot, and 2 broken idler wheels. Sled has been in shop since march, waiting for new W-arm and rails. Both are broken.
I am slowly hearing of updates ....I am sure Yamaha will take care of you guys....Dont quote me on this, just my gut feeling...and I have one hell of a gut....LOL
Convert
MrSled said:and I have one hell of a gut....LOL
I'll vouch for that LOL
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Hmmmmm, I have an EC Ohlins coming for my Attak and was thinking of selling it. But with the issues with the manual cable maybe I should reconsider....................
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You won't have problems with the cable once you have the updates done. They've added some protection to keep the track from touching it. Also Mighty, even though you have the EC Ohlins it still uses the manual cable as well.
Manual cable...it has a servo motor with wire...dont it?
- Apr 17, 2003
- Menno, SD
- Menno, SD
While the Öhlins® Mono Shock™ EC rear suspension delivers full range compression adjustability from handlebar, the rebound is adjustable via a clicker on the shock body.
The electronic part is for compression range adjustability only. The rebound is still adjusted by the clicker in the tunnel.
:ORC
I talked to Yamaha yesterday. Anyone with a 2005 RX-1 with Monoshock will be very happy. It sounds like you will be getting all the 2006 updates. I will have confirmation after the 2006 Snowmobile Tech seminar.
cobalt650
The boot ripped on my cable, and the cable pulled out of the shock. Will that require a new shock or will they stick the cable back in the old one? Any timeline on when Yamaha may or may not offer the updates? I'm hoping to avoid having to beg to have the bushings and slide rails addressed.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Not true, there's a knob at the bottom of the shock. The cable does not attach to the Ohlins. I can simply remove the cable assembly if I choose to install the Ohlins :ORCSrxspec said:Mighty, even though you have the EC Ohlins it still uses the manual cable as well.
