Got a fiew parts installed today belly pan, tunnel covers and a set
of wind deflectors on the light cowl, the lower deflectors were back
ordered.... Also got the bar pad and a CrossFire rear cargo rack
ordered. Next add a couple of alluminum angle braces under rear
tunnel for support of 3 gal gas can and install a turned out chrome tip
on the exhaust, then drill 2 rows of four 3/8" holes in the plastic
pannel below the Rad to let the melting snow drain off so you dont
get ice build up inside the pannel the next morning. Forgot one more
thing turned the Pod mounting brack over and remounted it.
All is needed now is snow............
yamrx1
PM you. No windshield with mtn ,the one here on floor comes with windshield...... Looks like it should be a fun sled in the deep.....More pics when you get the rest of the mods done........
To bad you not out you could get a little ride in on the woods road.....
Took off the stupid big windshield and the boys at Atlantic
wants me to change with them for a shorter style like the
GT or FX ? I'm changing with them but may leave it off all
together depends how cold it will be first.
TB
TB
Phazed-Coug
My mtn windshield hangs in the garage, I went out today, for
a leisurely ride(nothing to taxing) and was still plenty warm.
Blue shadow
Are you staying away from the turbo ,Bill?I will let you try my turbo if I see you around .That will change your mine .Sled looks nice.Any snow your way?
checkman39
- Sep 2, 2006
drilling holes to allow water drainoff is a great idea. I'm gonna do that tomorrow.
Blue Shadow,
Staying away for now. I'm building a cabin down in
the mountains this year and after that i'll think about
it again. How did you make out this year with the motor
mods change the pistons and rods? No snow just a couple
of light dustings so far.
Thanks have a good one....
TB
TB
Auskins
We got almost a foot yesterday here on the north east coast and it looks like its gonna stay
yamrx1
We have what they were calling for and light snow for mon. @tues. in the forecast,let it snow.All i need is my track put on and let it keep coming...
yamrx1
Auskins how can you be the best thing to come out of Baie Verte when you still live there.I think i'm the best thing to come out of Baie Verte ,i've been left since 84...
Just kidding
Phazed-Coug
Watch the rubbing on the flipped pod bracket.
I dropped mine to the headlight cover. Works great
hardly look at gauges much anyway.
I've got a rox riser on the way too, just 2 inches, but
just enough to be comfortable
Blue shadow
Just waiting for some snow to try it out.I now have my air filter on the outside ,will have to make some changes to the jetting for the high flow exhaust.Engine mods all done with 113 lob centers .My carb caps was all warp from the heat at about 20 tho,No wonder I could not get off the line with others ,but I would past them after 200 ft.Also running my fuel at 2 psi and did not no ,I now have them at 4 psi.Also put back my 24 /38 gearing from 22/38 .With a few changes to the clutch weights and I should be set.
Good stuff. Might catch you sometime throughout the
winter somewhere..
TB
winter somewhere..
TB
- 23K
