spddmon
annyone running the mpi issued breather or did they find them a bit too restrictive? i could hardly blow through the end piece of the tube so ime going to put some brass scowering pad into the end of the tube
Sterling
- Nov 4, 2005
I've been runnung mine for two winters now, no problems at all. Just don't route the hose over to the brake side like they show. I zip-tied mine to the steering column area. Reason is the crank gases carry a little oil as well as moisture and I didn't like that getting near my brake rotor and electrics. Don't worry about the little filter tho, it works good.
tko47
tko47
Breather hose has the arrows , works good in that spot
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
tko47,
What hose did you use?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
That is the hose supplied in the MPI kit. They recommend that you route it up towards the steering post, but tko routed it forward and it works well there!
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
OK, what size and type hose does MPI include in their kit?
tko47
Its like 3/4 oil return line hose with a 90 degree elbow right above where it slides on the engine
spddmon
i have the vent tube mounted to the cable guide on the steering tree. took it for a ride sat with the copper pad in the tube and end piece out on hard pac it doesnt vent make it work inthe powder it vents a steady stream up through the opening around the handlebars. its morelike a ring issue got to give them time to seatin
