Ethan_Messinger
- Jan 17, 2016
- Wisconsin
- 2011 Yamaha Nytro XTX
-need a new track for my 2011 Nytro XTX (144)
- I wanted something bigger than the 1.25 on it currently.
- Want anything from a 1.5-1.75 (I ride 80% trail, 20% off trail).
- Was wondering what track I can clear without making adjustments, and I don't want to be changing my gearing or anything. Any advice would help.
GYTR GEARHEAD
- Mar 10, 2015
- gatineau
- nytro xtx
you can go up to 1.75 without having to change anything if you stay in the trail more then anything i would go with the 1.6 cobra ice prestuded-need a new track for my 2011 Nytro XTX (144)
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
X2 on 1.6" ice cobra, that's what is on mine.
Sent from my Nexus 5X using Tapatalk
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
I went with the Talon 38 1.5" x 144 and Kimpex external drivers. I did not stud it!! If you deal with alot of ice you would be better off with the ice cobra.
Pete
Pete
radianguy
- Jan 1, 2007
To install a 1.75 track you will need to remove the tunnel protectors. The ones riveted to the tunnel aren't a problem bit the ones welded to the front heat exchanger are hard on the nerves.
With that said I waited 2 years to do the 1.75 track, wish I did it sooner.
Pete
X2. Have 250 miles on my talon 38. It's a rugged looks and feels rugged. Also did kimpex drivers, had to trim the teeth about 3/16 cause mine hit the rails.
herndonp
- Nov 28, 2012
- Freedom,NH
Nick. That's weird you had to trim as mine don't hit. Was yours a stock XTX?
Pete
Pete
Pete
Yes stock 2009. I don't understand what changed to make them not hit. But all the reading I did indicates it was a problem on early year nytos, most guys trimmed the rails. They barely rubbed.
herndonp
- Nov 28, 2012
- Freedom,NH
Glad you got it figured out. I wonder what they changed.
Pete
Pete
Not sure. Has to be something with the position of the center arm. There were lots of threads on extroverts and having to trim the rails. I read yours didn't need it and was hoping mine would be the same. First test ride in the yard and it was very clear they were interfering.
herndonp
- Nov 28, 2012
- Freedom,NH
1700 miles no issues.
Pete
Pete
