scott boddie
- Dec 17, 2003
- braintree mass.
- 04 WARRIOR
my 04 warrior wont crank with the key it will crank with a screwdriver on the 2 wires on the solenoid and start if I hold the key and jump the starter solenoid and stop using the screwdriver it will keep cranking and start but the head light is very dull if I unplug the plug on the solenoid the power is good to the lights and dash if I plug the wires back in to the solenoid they get very dull the kill switch works and the key switch works if I jump solenoid for a split second it will keep cranking with the key WTF... has anybody had this issue I have no clue !!!
Bigfish
- Sep 7, 2009
- 15 RS Venture TF
04 RX-1 ER
Bad ignition switch???
So with the key in the on position you can jump the solenoid? Sounds like a bad solenoid. Had this happen on my 09 Nytro.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Dumb question? Is the kill switch up? They will not crank otherwise! Just sayin
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Go through this with the wife a lot, tell her to use the ignition key not the kill switch. There only for EMERGENCIES and if the switch should fail it will not crank/restart.
scott boddie
- Dec 17, 2003
- braintree mass.
- 04 WARRIOR
i tried jumping from the battery pos .to the first fuse my sled works fine I think ign .both sides of the fuse have power that way everything works great but no power fuse is good key works and kill switch works
scott boddie
- Dec 17, 2003
- braintree mass.
- 04 WARRIOR
i tried jumping from the battery pos .to the first fuse my sled works fine I think ign .both sides of the fuse have power that way everything works great but no power without jumper wire fuse is good key works and kill switch works
scott boddie
- Dec 17, 2003
- braintree mass.
- 04 WARRIOR
sorry I didn't finish my sled is still not working .if I don't run the jumper wire from battery to the first fuse it acts like no power to crank has anybody had this issue NEED YOUR HELP !!!
Post a picture of your jumper, I bet the relay by the batter is shot.
Indy
I've had the problem, I added a starter switch for a short time until the permanent fix. Sounds like a bad solenoid to me. Mine was bad, I now have an extra just in case. I have also lost the ground. I ran a wire from the solenoid to the frame, problem fixed.
