ualav8
the front left bolt on my pro action skid just spins and spins when i try to remove it. im assuming theres some internal nut that has broken loose and s spinning inside the w arm. any suggestions??
4strokelover87
no, there is not internal nut, just an aluminum shaft that's threaded on both ends. What I usually end up doing is hitting it with a couple quick bursts with the impact!!! backs it right out every time!!! Good luck
i would sugest putting the bolt back in on the other side and snug it up and take out the bolt that wont back out it could be locktite that is perventing the easy removal
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
spddmon said:i would sugest putting the bolt back in on the other side and snug it up and take out the bolt that wont back out it could be locktite that is perventing the easy removal
Sometimes it takes a few tries, but eventually you will get it. It helps to have power, either an impact or drill.
cjrama
i cast a vote for impact gun
ahicks
If no power available, and you can come up with a nut that will fit the bolt already removed, install the nut all the way up on the removed bolt, reinstall the bolt most of the way, then use the nut as a jam nut to tighten. This should allow you to free the side you're struggling with. Then use 2 wrenches to loosen your bolt with jam nut and go on to whatever it was you were going to do when you got into trouble.
dcstewart77
Back out one side (side A) about 1/2" slip a 12mm open end wrench over the threads and tighten the bolt onto the wrench.
You should be able to loosen the other side now (side B).
Go back to side A, should be able to loosen bolt, remove wrench, and back the bolt all the way out.
Doug
Doug
LazyBastard
Remove one bolt, lube it up real good and put it back (maybe in and out a few times to clean the threads if it doesn't turn completely easily), then remove the second bolt, then back to the one you greased.
And keep your mind out of the gutter.
LazyBastard said:Remove one bolt, lube it up real good and put it back (maybe in and out a few times to clean the threads if it doesn't turn completely easily), then remove the second bolt, then back to the one you greased.
X2 thats what I ended up doing on my new to me rx warrior..... I think the previouse owner used locktight.... I hate that stuff.
LazyBastard
Great on some things... just not spinning rods.jd0270 said:X2 thats what I ended up doing on my new to me rx warrior..... I think the previouse owner used locktight.... I hate that stuff.
- 6K
