2005 vector
I removed the 3 bolts that hold it to the tunnel. If I try to pry it from the bottom, I can see it move on the driveshaft bearing. So, I think it is hung up on the jackshaft bearing. Do I need to remove the jackshaft in order to get the chaincase off? Ultimate goal here is to replace the lower chaincase bearing.
BTW, I tried to remove the jackshaft per the instructions in the tech section. I rapped on it pretty good using hammer and wood, but could not get it to budge. I can't imagine what is holding it on. I removed the threaded collar on the secondary side, is there anything else I forgot?
Thanks for any help.
Flipper
- Oct 31, 2003
- Ottawa, ON
- 2018 SideWinder LTX LE 50th
- Ottawa
You do not have to remove the jack shaft to get the chain case cover off and replace the lower bearing.
I remember my cover was on there pretty good too when I did my bearings last year. If I recall correctly, I worked it off with a pry bar.
DoktorC
Is your skid in or out? If it's not out it's easier if it is or at the very least the track is VERY loose..
Make sure the chaincase is coming off straight or it'll bind real bad...lots of jiggling and swearing and it'll come off.
Aaron Eh
I hit mine with a rubber mallet a few times to get broke free from the chassis.
milljk
Guys, What size nut is that holding on the driven sprocket? Trying to get mine off but have nothing that big. Also how do you hold the jack shaft while removing the nut? Any help is appreciated.
It's a 36mm nut.milljk said:Guys, What size nut is that holding on the driven sprocket? Trying to get mine off but have nothing that big. Also how do you hold the jack shaft while removing the nut? Any help is appreciated.
I just had my dad holding the secondary while I undid the nut.
milljk
Thanks RSV, After reading my post again, it sounds like some passage out of a dirty magazine.
LoneViper
I used a big creascent wrench on the driven nut and a second crescent wrench on the drive shaft letting it rest aginst the crossmember in the suspension.
Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Hold the brake lever, to stop everything in your chaincase from turning!
Hmmm, well, that's kinda hard since you have to remove the brake to get the outer cover off... LOLRoger said:Hold the brake lever, to stop everything in your chaincase from turning!
On a Doo or others where the brake is on the inside of the chaincase, you could hold it with the brake...
Roger
- Feb 10, 2007
2006 Indy 500
Sorry man. Never even looked. Had lots of Polaris' apart and always used the brake. Had one Yamaha Venture apart 5 years ago and have forgotten. Good luck.
p0wd3rp1l0t
did u ever get the cover off?
