BoonDock Saint
im getting a code 84 and the yellow light blinking, engine sign i believe is also blinking, does anyone know what this code mean? much help would be apreciated
Daranello
Suspended
if I remember right code 84 is TORS.
BoonDock Saint
yes its TORs, wonder why that code appears, frozen ice or something? when i start it, doesnt sound right, like mis firing pistons, idles slower then usual, the TORS icon shows, I thought it was the engine sign at first
LJ 452
Tors, didn't know they had a special icon for that. Have you done any work to the sled lately? any additional riser, change in pivit position? Check the cable routing and ensure you have some endplay in the throttle itself. Also make sure you hear the micro switch click on when you just start to push the throttle. There is a bypass proceedure that you can do if needed but I would recomend fixing the issue as a stuck throttle with out tors would turn your sled into a 600 lb missle.
msg
Can someone explain to me what TORS is? Thanks
BlueBlood
Throttle Over Ride System---Safety feature that limits RPM in case throttle sticks. If the ECU doesn't recieve signal from the micro switch at the throttle lever and the Throttle Posistion Sensor when you push the throttle, TORS activates. So you don't have a runaway sled in case the cable ices or other various things. Hopefully I explained it right and it made sense.
BoonDock Saint
xtx totally stock, just HID headlight upgrade, and adjusted throttle position when it was new, never had the problem till couple days ago
