tatalover78-2
started the sled after the summer build. when I plugged in the gauge to see things, I noticed the far left light was on, the fuel tank gauge showed full and was flashing. I didn't notice any codes. Notes of interest: during the build I had the fuel tank, airbox, and battery out.
Any ideas on how to fix this? all connections where checked and appeared good with no loose wires or hanging unplugged connections.
thx much in advance
thx much in advance
Maybe the float got stuck when tank was out I would loosen tank and shake it around some.
tatalover78-2
I will try that. I did also have the sled (tank installed) on its side 1/2 dozen times playing with the suspension. I'll let you know
thanks
thanks
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
what did you build up on the sled? you sometimes have to let the guage sit for a minute before you get a acurrate reading of whats in the tank just a suggestion
tatalover78-2
4 shocks, skis, track / rair extensions, cluthes/PC, airbox, exhaust
just your typical things
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Just to clarify the fuel guage says its full but the low fuel warning light is on?
tatalover78-2
no sure. the far left yellow light is on and the gauge has all the bars full and is blinking.
no codes appear
no codes appear
- Nov 1, 2009
- 2009 Phazer RTX
if you turn the key one position you should be able to see the lights again without starting it up. I don't think it has anything to do with fuel if the pod shows its full.
I had that failure when i missed to connect the floats cable in the front of the tank to the harness
tatalover78-2
took the tank out, I missed the plug.
thanks guys
thanks guys
