bjd68
- Oct 8, 2012
So was out today and my dad ended up hitting a small branch on a tree, it didnt even stop the sled but after looking at it the one ski is pushed back about a inch from the other ski
so im thinking after reading on here its a bent subframe, what a joke this 2010 nytro mtx se 162 only has 70 miles on it and it should have never bent that easy! So my question is how
much is a subframe? How much work is it to replace? Also my dad says just maybe leave it because it doesnt seem to handle any different! So is it ok to leave it bent or is it better to fix
it right away? Also can u bend it back somehow? Any info would be great! thanks Brent!
LM7800
- Dec 4, 2011
- ohio
- 2016 viper ltx LE sold
gusset kit works great to beef up the frame after you get it straight or buy new
Grab a big pipe and bent it back, then add the gussets... its about the best thing you can do.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
It's not that big a deal to remove if you have to take it off. Just don't do like I did where I ripped it out in the spring and just started getting it back together now with a tough time remembering how the front end went back together (ie what bolts went where).
bjd68
- Oct 8, 2012
If I were to bend it back does anyone know whats the best way to do that? Also where can u buy a gusset kit?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
A large pry bar between the upper and lower arms. Grizz tracks is a member on this site who makes the gusset kit.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Be careful where you put the pry bar when bending it back. Do it where there is a good strong point, ie. spindle or cross member...else you could collapse an A arm tube...I bent mine a bit when I first did it.
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
This thread should help you out. PM Grizztracks for a gusset kit. Check out his photobucket. I put mine in ths summer after it bent last year at about 7 mph.
http://www.ty4stroke.com/viewtopic.php? ... d&start=15
mattyg1405
be careful and if you have the stock bushings your just going to be compressiong those. im a fabricator and i straightened mine as best i could and then added gussets last season, this season i will definetly be buying a new sub frame and gusseting it before it bends for sure. its not possible to get it back to stock once its bent from an impact (if its really bent)
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
All the measurements on my straightened subframe are consistant with a new one. It came out perfect.
