Skiduty
- Feb 5, 2024
- Iroquois, Ontario
- 2008 Yamaha Nytro, 03 MXZ 600, 02 MXZ 500F, 05 600SDI
Hello people, I can do a little more research and probably find the answer but thought it would be easier to ask. I put a new belt on my 08 Nytro Fx and it has been squealing since. I have drove it roughly 20 kilometers since hoping it would stretch a little and stop but it hasn’t. I looked into a little bit and if I remember correctly, there are 3 screws in the backside of the secondary? That I can take out and either remove or add washers to, to open the secondary up a bit? Is this correct? I also had the secondary off to clean and grease the jack shaft and driveshaft bearings but I’m positive I put everything back the way it was. I also found that the primary sheaves were just a little warmer than they should be, I think, they were a little warmer than my ski Doo 500F anyways. Am I on the right track with the washers on the back of the secondary?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Yes you are. Need to open the secondary a bit for the new belt.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
Thank you @Yamajon1 for confirming , I will have a look in the manual before i go ahead.Yes you are. Need to open the secondary a bit for the new belt.
The tips of those bolts wear down.
Replace them or remove the washers.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
Hi guys, just getting back to this now. I had put the new drive belt in my 08 Nytro and after it was squealing at idle. It is sitting above the secondary so as mentioned above I will need to remove the washers in the back of the secondary. Please excuse my inexperience and probably super basic questions but I just want to make sure if a few things first. I took a look and can see that there is indeed washers in those screws but I can’t tell whether they are 1mm or .5 mm spacers. If they are 1mm spacers then I’m going to try putting .5 ones in. My first question is can I use any washer that is .5mm thick or should I order the OEM PN 90201-06H1 washers? Also is this as simple as removing the secondary, changing the washers, and putting it back together? Nothings going to explode on me? Lol. And the manual says to grease the fixed sheave splines with Esso beacon 325 grease or Aeroshell 7A. Not sure how hard it is to get this grease? But what are you guys using?
i use oe washers.
pretty much any grease will work.
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
Thank you, I will see if the Yamaha dealer has them in stock.i use oe washers.
Unless you're into drag racing from a standing start, don't worry about the .5mm washers. Just take out the stock washers and the put the bolts back in without them. Save yourself from being overcharged some $$$
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
Thank you, No, no drag racing for me. I was thinking of trying that, I just wasn’t sure if taking the washers out would bring me to the right height? I think the belt height is supposed to be between .5mm below the outer edge to 1.5mm above but I would have to check again to be sure. So just taking them completely out will get me where it needs to be then?Unless you're into drag racing from a standing start, don't worry about the .5mm washers. Just take out the stock washers and the put the bolts back in without them. Save yourself from being overcharged some $$$
Skiduty
- Feb 5, 2024
- Iroquois, Ontario
- 21K
