scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
So when I start it cold theres no squealing and if you pick up the back the track will only move about 3-4" and stops but after you ride it for awhile when you stop you can hear squealing sometimes and if you pick up the back the track continually rotates. The belt is about 1/16th" above the top of the secondary . Need adjustment? Thanks
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Sounds like you need to loosen the deflection yes.
scottt
- Jan 30, 2018
- maine
Watched a youtube video since Ive never done this before. REquires removing the secondary,,correct?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
No! Just need to take the secondary bolt out and put the shim(washer) back between the head and aluminum spacer if it's not there.
scottt
- Jan 30, 2018
- maine
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Why do people think the belt has to be 1/8 in above secondary? It doesn’t matter , belt deflection measured with straight edge clutch to clutch with ruler pushing down on belt ,measuring about 1 1/4 ,1/2 look in manual you don’t want squealing and track moving you’ll have wear.
scottt
- Jan 30, 2018
- maine
I didn't say it had to be..just noted mine is about a 1/16" above. I'm asking because I've never had to adjust any sled for deflection and never done it before. The old 8jp belt that was on it didn't squeal but when it exploded and I put on a new 8jp it squealed and creeped off the ground at operating temperature. Never messed with sleds much...just rode them.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The belt should be right at the top/even with sheaves or even slightly below them.. That's my experience with it. I think your a little to tight where you described it was just over the sheaves. (deflection to tight)
If you blew a belt the offset(different then deflection) is probably off.. It was possible wrong to start causing you to overheat the belt and break it.. ALSO when these winders blow belts it causes the stub shaft to move in slightly.. This will cause continual problems with belts(offset).. Plenty of posts on here about this.. Stub shaft moves when blowing belts
