New gas tank needed for turbos
So you guys still have to reduce the size of the tank for front mount turbos??? That is going to be a deciding factor when i am turbo hunting,now you guys saying mc only looses .7 of a gal. and simons looses 1.5 gal. is that correct,cause 1.5 gal. is alot when we only have 10 to start with,now when i had my 03 stocker the way i drive i was only getting 10 mpg sometimes and at best 14 only a couple of times,now i would really be back to looking for fuel,just like this year with my confusion... :(
if you put 2 compartiment tank you need 2 return line , i put a 4 liter tank in the front, in 2 years only use it 1 time, i do all my sled time on groomed trail or race track, i do the same mileage then other sled with no turbo or two stroke. thebest
I have ran out in 41 miles at 18lbs wet heavy snow in the deep and steep no groomed trails here the very best I can get in the mountains is about 7mpg it takes fuel to make hp and if you are running the boost like we have to in the mountains your going to use alot of fuel, I would like to see a tank for the front mounts with out the exhaust cut out in the bottom as my exhaust dumps into the front of the tunnel that would be good for at least another gallon
Tank
What are you thinking of making it from plastic or aluminum .I think if a fellow had some time he could also remove some of the seat and make the tank a little larger .To make up for the loss with the turbo and for the duel tank.just a thought
