- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Thank you for the phone call yesterday WinterWolf, glad I could answer your questions
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Thank you for the phone call yesterday WinterWolf, glad I could answer your questions![]()
Terry I also spoke with you yesterday re the Pro 4 spacer issue. I sincerely appreciate you taking the time to walk me through the install logic on that. Thank you!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
You are very welcome
sledding rocks
- Feb 11, 2017
- north
- sidewinder
well there shipping my Tapp primary today ,
there setting me up with the black primary spring , 1mm roller , xxx ramps ,set on a , not sure about how much weight on the arms , can any of u guys using the Tapp primary what r u starting out with weight on your arms ? any info would be great to start with , I will be using the xs825 belt , thanks
WinterWolf
- Mar 25, 2017
- Connecticut
It’s all gonna depend on what you have...are you stock? Are you tuned? What tunes? SM? PM? Header? A bundle? Just one Tune? What’s the secondary you’re running with it? Stock secondary? Aftermarket Secondary? Etc etc...
The TAPP IS SUPER Adjustable...quick and easy. Start it out with how they send it to you, and see how it works with your secondary? And go from there.
WinterWolf
- Mar 25, 2017
- Connecticut
So I’m in N. Maine doing some riding, and made some adjustments to dial in the TAPP and Pro 4.
Wrapped my secondary spring one hole tighter, and switched my clickers from #3 to #4 on the TAPP. What a huge difference! Sled runs like a total beast. TAPP and Pro 4 and XS825 now seem to work beautifully together(21/41 stock gearing). The new SS SM tunes from Hurricane are Fabo. Wants to pull your arms out of your sockets.
Think I have it where I want it....gonna leave it be now. Very happy. Super smooth and silky...but very very explosive with just a touch of throttle.
BTW...On the Powder Lites-TAPP Primary Website, they are using the picture of my clutches/machine as their advertisement for their product lol. I didn’t know that till I went on the site and found it!! Pretty cool.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
What are your clutch temps cruising/top end?
sledding rocks
- Feb 11, 2017
- north
- sidewinder
im tuned for 300hp , / header , I will start off with the stock secondary , 35 helix and see were this takes me , thanksIt’s all gonna depend on what you have...are you stock? Are you tuned? What tunes? SM? PM? Header? A bundle? Just one Tune? What’s the secondary you’re running with it? Stock secondary? Aftermarket Secondary? Etc etc...
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Wrapped my secondary spring one hole tighter, and switched my clickers from #3 to #4 on the TAPP. What a huge difference! Sled runs like a total beast. TAPP and Pro 4 and XS825 now seem to work beautifully together(21/41 stock g.
One hole tighter on the secondary. Do you mean one from center or one from a previous setting? Did you adjust the clickers at the same time?What where the RPM changes with the adjustments?
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
WinterWolf, are you running any allen screw weights or any washers on the roller thru bolts? I'm spinning 9300 WOT clickers on 3 no added weights trying to tame this thing down. Talked to Dave at TAPP yesterday and today, and I'm going to add some allen screws and washers to start getting this WOT RPM under control. Thanks.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
What belt/tune are you running?WinterWolf, are you running any allen screw weights or any washers on the roller thru bolts? I'm spinning 9300 WOT clickers on 3 no added weights trying to tame this thing down. Talked to Dave at TAPP yesterday and today, and I'm going to add some allen screws and washers to start getting this WOT RPM under control. Thanks.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
STAIN, XS825, TD Max Spool 17, 25% VP C16, header, CAI, BOV, Pro 4 secondary, 43/34 helix. My a/f is good at WOT ~11.8-12.2.
I'm not studded. Adding 192 1.575" Gold Diggers this weekend though. I'm expecting that to zap a few RPM's off the top end, right?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
No studs on that much HP? Yikes!!! That thing must be dangerous!!!
Traction should bring the RPM down. After that 1 gram added to each arm( 4 grams total ) should bring the RPM down @150-200 rpm per gram.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Traction should bring the RPM down. After that 1 gram added to each arm( 4 grams total ) should bring the RPM down @100 rpm per gram.
Thanks for that insight. Yes it's stupid loose even at 100+ mph punching WOT. Zero traction.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
what helix and spring r u using on your pro 4 ? im currently ordering one also , thanksSo I’m in N. Maine doing some riding, and made some adjustments to dial in the TAPP and Pro 4.
