Eighty8LE
- Mar 19, 2015
- 15 viper ltx LE
Looked under my sled in the garage and it looks like it has been leaking oil since I put it away. Upon quick inspection I could not tell where it is coming from. Any ideas what would be the likely culprit? It is on the exhaust side and is motor oil. I swear ive put more oil into this sled than past 2 strokes.
Check the drain plug or one of the lines on the bottom of the tank.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Probably the sealant between the oil tank and chain case cover.
And look for cracks on tank.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
It could just be some spill from the last spring change.....hopeful thinking.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Not sure if you changed the oil when you put it away, but if that's the case did the oil filter o ring stick to the block on the old filter. This is very common.
Also the lines at the bottom of the oil tank can rub.
waldo1
chain case cover leaking - pull it, clean it, file it flat where possible, reseal it with silicone around gasket.
