Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
My dealer says there may not be enough turbos built to fill all the orders. What they do build, will be on time.
stgdz
- Mar 27, 2021
- Buffalo MN
Arctic Cat's New Platform
Arctic Cat’s new snowmobile platform, coming in 2023, will span our mountain, crossover and trail sled families, and will give everyone the ride of their life.
Two stroke getting shown at haydays.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
You can go to cat site and "name" the new platform. Pro-Cross2 would not be a name I would use.Arctic Cat's New Platform
Arctic Cat’s new snowmobile platform, coming in 2023, will span our mountain, crossover and trail sled families, and will give everyone the ride of their life.arcticcat.txtsv.com
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I want to know how can one name it without seeing it. Hype at its finest, gets everyone talking I guess. Sure hope they will still use Yamaha for the four-stroke power plant so we can at least get a piece of it that good, and hopefully its engineered properly this go around. They sure won't survive another 2012 fiasco.
stgdz
- Mar 27, 2021
- Buffalo MN
Mike are they going to put the 998 in it?
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
One of the articles talking about this new Chassis he said it will be for all of the two-stroke models. I’d imagine down the road they will have it as a turbo but it appears for the first year or two it will be two-stroke only
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
Having it for two strokes first makes sense to get them in the field. I remember the Firecat chassis. Very light, very fast, but you could break it in half. Cat became concerned then built the Twin Spar chassis which was heavy and unbreakable. Then came our beloved Pro Cross.
My guess is that the new chassis will be light, have a fancy gauge and enough electrical power to run power steering in a two stroke. We will see and hope it not named "too little, too late"
Turboflash
- Mar 18, 2019
- Southern MN
Can you say 850-900 2 smoke?Having it for two strokes first makes sense to get them in the field. I remember the Firecat chassis. Very light, very fast, but you could break it in half. Cat became concerned then built the Twin Spar chassis which was heavy and unbreakable. Then came our beloved Pro Cross.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
At the top of the line, I would guess 180ish HP turbo 2 stroke, new chassis, new gauge, maybe power steering. I will be happy to continue riding my antiquated 22' Tcat EPS.Can you say 850-900 2 smoke?
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
If the pics online that surfaced are correct it’s just a slightly different variation of the pro Cross. Hood is definitely changed. But spindles and such look same.
stgdz
- Mar 27, 2021
- Buffalo MN
Front suspensions on all three mfgs have not changed since 2015If the pics online that surfaced are correct it’s just a slightly different variation of the pro Cross. Hood is definitely changed. But spindles and such look same.
Todd Beenen
- Feb 16, 2020
- Michigan
- 2020 T-Cat
maybe someone could correct me but didn’t the process change the front suspension in 2020? Maybe not much , but it did change. It’s called the ARS 2.
stgdz
- Mar 27, 2021
- Buffalo MN
The spindle and the a-arm changed but the mount points to the bulkhead are the same. Poo and doo's bulkheads haven't changed. The body work did.maybe someone could correct me but didn’t the process change the front suspension in 2020? Maybe not much , but it did change. It’s called the ARS 2.
Todd Beenen
- Feb 16, 2020
- Michigan
- 2020 T-Cat
So it did change? That’s what I thought, there’s no way cats front suspension from 15 is the same as a current model
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
A arms and Spindles have been the front end of choice since Cat invented it. Everything since then has been an improved version for all the manufacturers. I don't see trailing arms or pogo sticks returning. A arms and spindles will be the future.Front suspensions on all three mfgs have not changed since 2015
