DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You better watch this video.II think I have 4-5 hood pieces to remove to get to the fuse box. Yes the hardware is there but the access is not like two screws between two body panels. Not sure how they did it (1/4 pneumatic screw gun? . I guess it will be easier next time I'm going to try to install Pushpins for body hardware that's difficult to remove/hidden
sab2022
- Feb 21, 2020
- Maine
- 2023 Sidewinder S-TX GT
stevewithOCD - thanks for your hood description I think I got it figured out... I wondered what those d-links were for .... these snow. all modern snowmobiles are new to me ....
sab2022
- Feb 21, 2020
- Maine
Just repainted this thread, DMC for the video, excellent.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
You may also want to drill out all the rivets on the lower side panels and add rivet nuts to make them removable!!stevewithOCD - thanks for your hood description I think I got it figured out... I wondered what those d-links were for .... these snow. all modern snowmobiles are new to me ....
It makes oil changes, chaincase and clutch maintenance easier and save you from having to clean up oil mess
Turboflash
- Mar 18, 2019
- Southern MN
I went with Duraflex; rail mounted carbide-tipped. I wanted to be able to back up easily without bending scratcher and be able to cross RR tracks.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/
Here is a link to Rockerdan's build thread pretty well all information about maintenance and mods are here for sidewinders.
#51 in the build thread shows you step by step to modify lower side panels for easy removal
sab2022
- Feb 21, 2020
- Maine
Yamamerc - Excellent, thank you I've been a subscriber to this forum these March when I got sled. I'll copy that thread onto my OneNote file. Number one on listhowever, is a lift for 665 lbs. 2-up sled and a idiots guide to snowmobile components and terminology. I feel the best source of information is the IPB.
Heffe
- Nov 3, 2015
- Eastern Ontario
- 2012 vector
2012 apex xtx
2019 renegade 900 ace
2020 renegade 900turbo
2020 sidewinder ltx gt
1980 et 300
1987 phazer
I just read through the whole thing, what a great resource to have. Thanks for all the replies, what a great site!https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
It is a great site. If you become a VIP member for a few bucks a year that goes to keep the site up and running you can get access to factory service manuals also.I just read through the whole thing, what a great resource to have. Thanks for all the replies, what a great site!
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
SAB, we're here for you and your 32 "Veteran" posts.
There are NO stupid questions, especially in the summer when were Jonesin' to type something.
Now we MAY have to work on your On-Line Grammar cuz i had to re-read your posts 6 times to figure out what the hell you were saying, but we're in this together.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I have 2 of these lifts and they work well!! No problem lifting 665lbs I believe they have a 1000lbs rating. Try to find one with wheel so you can move around sled in garage when on lift!
I also made the manual hand crank to fit on a drill to raise and lower lift.
If you do this avoid using a impact to raise and lower. The hammering action off the Impact will damage the threads on the lift cylinder
https://www.amazon.ca/Extreme-Max-S...ocphy=1002441&hvtargid=pla-569447300590&psc=1
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Also check out the sticky Master list of issues and fixes. Don't go crazy trying to fix them all before riding just be aware and if you have a issue it will help you figure it out better on a trail. It may look like a giant POS when you read through everything but just try to ride and enjoy they are fun sleds!
sailor joe
- Apr 4, 2019
- ma
- 2016 RS VENTURE TF
2020 SIDEWINDER GT
true I found this outI have 2 of these lifts and they work well!! No problem lifting 665lbs I believe they have a 1000lbs rating. Try to find one with wheel so you can move around sled in garage when on lift!
