Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
I was reading over at HCS a new pilot jet is coming to fix the lean idle...
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
So both my friend's ZR200 and I manged to flood both machine 3 times now. Had to remove plug, heat it up with a lighter and put it back in. I even tried 1/3 choke two pulls then no choke. Same thing. This was at -20C in my shed. I'm changing the sparkplug for Iridium since I never was able to foul these on my SRX, I can't imagine doing it with a 4 cycle.
3six7
- Jan 26, 2018
- Saskatchewan
- Viper XTX
If you unplug the throttle safety switch (for lack of better term) you can start sled using throttle rather than the throttle lever needing to be pushed against the switch.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I find choke and full throttle works to start it every time. Never fouled a plug and did not have to disconnect the throttle safety switch. Hot or cold, i start it with full throttle. Small gas engines like these typically have a governor that the holds throttle at full open until it starts and then govorner pulls throttle shut against the idle stop screw.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
I'll give it a try when cold perhaps it will limit my pulling from 8-10 tries. When hot I start it with just a bit of throttle first pull.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
All I can say is this little SnoScoot 200 is a blast. I was one of the dealers to be fortunate enough to test pilot these units in Huntsville. They accelerated well and had speeds of 25mph plus with a 200lb rider on them. Suspension was great and cornering was excellent.
Step up kits for this unit will be available as well.
I believe at $3799.00 this is a great price point unit. It does have very limited availability and small margins for the dealers this season. I believe if you can get one at these great little units at list price with the Yamaha $100 acc option included you are doing well.
Do you know if the ones you tested had the 'Heavy Duty Spring kit' installed?
I ordered a 2019 for my daughter, but my wife will most likely ride it also and I am wondering if I need to get the spring kit for her. She's about 100lbs.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
The suspension has 3 settings. At 100lbs she's a featherweight and the second spring setting should be plenty. My wife rides with my 3 year old on our land at that settings no problem.
- 16K
