A
Anonymous
BlueRx
A
Anonymous
Apex_GT
Ok I'm a moron...So I went to the ofsc web site..Downloaded adobe the could view the trail maps..YAY Now if I could just figure out how to put the maps on my GPS I would be very very happy..Can this be done?? I tried saving it into "back ground" maps but I got nothing...HELP ME please
rws
- Jan 3, 2007
- North Dakota
- 2015 Arctic Cat XF8000 SnoPro Limited
I made up some trail maps that install into Mapsource where you can then pick the map and upload it to your GPSr. The map is transparent so your basemap (or any Garmin detailed map ie Topo, City Select etc that is uploaded along with the trail map) will show through.
MI UP trails
Grayling/Gaylord area trails
Cadillac area trails
MI UP trails
GPS Snowmobile Trail Maps Site
Here's a fairly new GPS snowmobile trails map site where you can post your GPS tracks to share and download tracks shared by others.
The site currently has maps for trails in MN, NY and Ontario and supports Garmin, Magellan and Lowrance GPS units.
http://gpssledmaps.com/
Tom Lee
Trail maps
Here is a link to trails in Labrador.
http://www.labradorwintertrails.com/trailmaps.htm
and here
http://www.labradorwintertrails.com/LWT003.htm
and here
RX1-er-2005
TTT
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The official sled trail system, published on the web site of the County Governor of Finnmark, Norway
http://www.fylkesmannen.no/hoved.aspx?m=1870
Trail map for Finnmark
http://www.fylkesmannen.no/SkuterA4_s0k ... 4.pdf.file
GPS map for the trail system of Finnmark
http://www.fylkesmannen.no/skuter2007_g ... x.zip.file
SRX Boy
Re: GPS Snowmobile Trail Maps Site
Have you had any luck downloading these maps and using them?? I have not. I have a Garmin 60CX and use Mapsource. Any help you could provide would be much appreciated.
Tony
bill-jr said:Here's a fairly new GPS snowmobile trails map site where you can post your GPS tracks to share and download tracks shared by others.
Tony
reved
SRX Boy said:bill-jr said:Here's a fairly new GPS snowmobile trails map site where you can post your GPS tracks to share and download tracks shared by others.
Tony
If you are having trouble try contacting sledzepplin. I have used and contributed to his site and the maps work fine. What Kind of trouble are you having? Remember when you load maps to a Garmin device, you must select all the maps you want and upload them to the GPSr at the same time. I have made my own transparant version and it works fine. If your looking for an Ontario map, I have one here.
sledzeppelin
Can you describe where you're running into problems? I'd be happy to help if you can give me a little more information.
SRX Boy said:Have you had any luck downloading these maps and using them?? I have not. I have a Garmin 60CX and use Mapsource. Any help you could provide would be much appreciated.
Grasshopper
- 13K
