davey
- Oct 9, 2010
wondering if anybody else is having this issue. When i start my viper in the morning and its cold out, my reverse wont work. i need to drive about 10 miles before it will start to work. This is the 2nd time it has happened, good thing i can drive out the other end of car port
Must have the Alison transition I. It?
09nytro
No I'm not having this or have I heard of it , most likely there this moisture in there .
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
No "R" on gage pod or beeping?
Can you hear any normal reverse engagement noises when reverse button is engaged?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Definitely check your chaincase oil...to see if there is any and if there is water in there.
davey
- Oct 9, 2010
well oïl seems to be good. There is no click or r or beeping.like there is no power heading to servo.i appreciate the responses must be isolated issue. leaving for a week long trip hope we have no issues.
JP270NYTRO
I had this happen on my 1100 turbo it was the reverse actuator went bad
davey
- Oct 9, 2010
took it into dealer they think could be a bad relay very hard problem to fix when it wont do it all the time.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Cat junk
09nytro
Really !!!!!!!!!Tarzan said:Cat junk
So you think your nytro is that much better !!!
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Until you get it fixed, I would be backing it into the carport.
- Apr 14, 2003
- Hessel, Michigan
No problems here
stingray719
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
I have the same problem - but its happening now in whether it is -20 C or -40 C outside. Has your chaincase been updated per the bulletin? After this started happening on mine, my chaincase came out of gear at 140 km/h down the lake. After coming to a stop, I shut the engine off and I was able to turn my secondary by hand and it wouldn't turn the driveshaft/drivers. I put the unit on its side to inspect underneath, found nothing. When I put the unit back on its track an grabbed the secondary to try and spin it again, the chaincase went back into gear and I was able to drive it home per usual afterwards. I haven't ridden it since. Bulletin parts are backordered. Not sure if it is related to the reverse issue but I would think so.
davey
- Oct 9, 2010
Mine did come out of gear once at around 80 mph. I put another 750 miles on and never came out of gear again. It's at the dealers now the update parts came in and are being installed today. I will be backing it in for our trip but I will be checking it every morning.
