APM
- Jan 8, 2018
- Fremont WI
- 2018 Sidewinder MTX LE 162–sold
2018 Sidewinder LTX LE 137
2015 Viper LTX SE 137
1999 Venture 700 triple--2 UP
2022 Ski Doo Summit Expert 850 Turbo 165 track
Great forum and many thanks in advance!
I have a 2018 Sidewinder LTX LE 137 track and a 2018 Sidewinder MTX LE 162 track (50th Anniv)
Just got back from riding in Wyoming in the mountains. The mountain sidewinder would not start two days in a row the following morning after sitting all night outside. The trail sidewinder started no problems in the same conditions.
I know about the relay problems and even had a spare set with me. Switched them out and still nothing. Motor turns over but no dash lights, no fuel pump sound, etc. I have a heated trailer so I fired up the heat and let the sled sit. It took 3 hours before it would start. I'm concerned because you would think by replacing the relays with new ones or warming up the existing relays would solve the problem but it didn't. I was only able to get it going by putting the sled in a heated trailer--for about 3 hours. I've read about guys on the forum who just warm up the relays in their hands and reinstall them but this wasn't the case for me.
Last day of riding we packed up to go home the same night. Drove sled in trailer and starting the trek back to WI. Of course, sled fires right up now with no issues. Only difference is that it didn't sit outside over night. Go figure.
Regardless, has anyone switched out relays to a steady state relay? Or maybe another brand? Diode grease? Anything?
Love these sidewinders for trail and mountains! The mountain sled is an absolute blast to ride in the steep and deep and it just keeps the power coming. The trail sidewinder version is night and day difference from my 2011 Apex SE--I'll probably get blasted for that but I'm in the camp who really likes this chassis! To each their own.
Thank you!
Thank you!
APM
- Jan 8, 2018
- Fremont WI
Just a quick update: I did order two relays from Ulmer Racing. These relays are in fact the Polaris relays. When I pulled back the tape it says Polaris right on them along with the part number. Regardless, I'm going to try them even though I'm not 100% convinced this is it based on my above post. Thank you.
Pierre Chenier
- Dec 14, 2018
- Sudbury
- 2019 SRX LE Sidewinder
My SRX has done the same thing. It doesn't seem to like the bitter cold. I left it in my trailer and when I tried to start it, nothing. It was -27 celcius. this has happened to me twice now. I never knew about the relays so now the machine stays in the garage and I load it up in the morning. The garage is insulated but not heated so it stays around -16 C. Never had an issue in the garage.
ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
No dash lights and no sound from the fuel pump is 99% the frozed relay. Happens more often if you start/warm up then shut off briefly but the symptoms are the same. I had one instance last week in Quebec around -10F. I had installed the Polaris relays. Switched back the the originals and had no issues the rest of the week. Go figure.
Pierre Chenier
- Dec 14, 2018
- Sudbury
I guess I should invest in some relays then, just in case. I'm assuming Yamaha knows of this issue and have not come up with a fix. I've herd talk of this on other threads so this isn't a new issue.
Mine has been sitting in an enclosed trailer all summer with some of my other sleds and last night I went to fire it up to take it off and ot barely turned over, so I hooked up the battery charger and I got it to briefly fire a few times then it would just crank and crank, I have all the lights on and I can hear the fuel pump cycle when the key is switched on and off.....I tried the kill switch as well.
Any ideas?
Any ideas?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
My guess - battery is not up to snuff. Maybe enough to power lights and fuel pump, but they really like a solid battery for starting. Can try jump starting or swapping battery with a better one.
Had the charger on it, was spinning over just fine
Could be a number of things:
-make sure it has at least 1/2 tank of fuel
-plugs may have fouled when cranking slow and barely firing
-could be simply flooded
-may have water in fuel and if its below freezing may be froze up
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
You could pull the fuel return line out of tank to confirm you are getting fuel. I had a fuel pump that would lose prime or not move fuel, ended up putting a walbro in
iceback
Do you have a tether on the mtx ?
I have had mine freeze , both closed and open . Going to try magnetic one from Cat .
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I never had the relay issues but I think Travis from barn of parts sells sealed relays for the 998
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Also Yamaha has a new updated relay that they were telling me at snowmobile show also others on ty.I never had the relay issues but I think Travis from barn of parts sells sealed relays for the 998
No tetherDo you have a tether on the mtx ?
