I assume my sled came with 87 and when i picked it up. Even the sticker says 87 I switched to 91 or 93 after the first tank. I noticed that it did not back fire as much and I also started to blurp the throttle every time I slowed down and when I did that it did not backfire anymore.
It also started allot better on warm starts. It seems this engine/ecu is pretty sensitive to fuel. I filled up in a blizzard and got just a tiny bit of snow in the tank. Well it ran like #*$&@ until the next fill up.
With so many having these issues and electrical issues and reading that our sleds might have a sensitive electrical system I wonder if i'm problem free because of the fuel and I plug it on the trickle when its not ridden?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
2400 miles, almost all have been on 87
Studroes144
2025 miles on the sled..1800+ have been on 87 octane
bleedyamaha
- Sep 28, 2013
- Northern Iowa
87
I always run 87. I never use kill switch and always let it idle.down before I shut it off. To start I always turn key a let it cycle than turn key until it starts.
MADDOG24
1,700 miles with 87 . My last fill up of the season will be 93. I try to run non ethanol when I can.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
87 on this viper and 87 on my nytro
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Ran 87 but 91 the motor seems smoother and doesn't backfire. Running 91 from now on, don't care what the manual says.
bottlerocket
Why is it back firing?
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
87
TD Max
Maybe some clarification on when it backfires?
After shutdown, during decel, etc.
X2 backfire on acceleration is more than likely the rev limiter.
87oct 3200mi no backfire ever.
christiansenkt
93 since purchase..
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
did it a couple of times on fuel that I got from a gas station other than petro-Canada or esso , tried 91 oct and right away the motor felt smoother.bottlerocket said:Why is it back firing?
RXVIPER
- Mar 4, 2010
- Shelburne ,Ont
- 2014 SR Viper LTX
2003 RX-1
Did it during decel.
