Pstn head
Tuner skis with 6" carbide square bars
dirk
birdmayon said:for the GYTRs, when people say almost no preload on the front shocks, or set to rattle then tighten one turn, this is with the skis on the ground, not lifted, correct? Cause when you do that and then lift the front end, the spring has a bunch of free space between itself and the adjuster nuts. Just want to make sure I'm understanding it correctly so my set up is OK. THanks.
It's with the sled lifted, if you loosen off the preload too much your spring won't be held in place when there's no load on the front end. Mine looks the same.
Thanks dirk.
LJ 452
Remove the preload on the front end. As mentioned, lot of track and studs to get it to turn. Try reducing the transfer a bit on the rear and see what happens. Due to te extra track/traction you may want to try a shaper bar, it won't likely help in the darting department but the other adjustments should. Never something as small as increasing rear skid preload could add to the front ski pressures, the sled is essentially a large teeter-totter.
Also 1600 miles is enough to toast a set of ball-joints (spherical ends) when the sled is raised to adjust the preload, check the free-play in the joints. Also a good time to check for any binding in the entire front end.
Dr. FeeLGooD
I have seen many posts about factory settings for limiter straps, however no posts about where factory settings are. Is it second hole from loose as possible?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
yamabrute said:I have seen many posts about factory settings for limiter straps, however no posts about where factory settings are. Is it second hole from loose as possible?
Stock is the first hole
There is a 3 hole and 4 hole version of the strap depending on where/when they come from !sorenson1610 said:yamabrute said:I have seen many posts about factory settings for limiter straps, however no posts about where factory settings are. Is it second hole from loose as possible?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
mewaschuk said:There is a 3 hole and 4 hole version of the strap depending on where/when they come from !sorenson1610 said:yamabrute said:I have seen many posts about factory settings for limiter straps, however no posts about where factory settings are. Is it second hole from loose as possible?
Didn't know that, which end is the extra hole? Tighter or looser
tighter i believe.sorenson1610 said:mewaschuk said:There is a 3 hole and 4 hole version of the strap depending on where/when they come from !sorenson1610 said:yamabrute said:I have seen many posts about factory settings for limiter straps, however no posts about where factory settings are. Is it second hole from loose as possible?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
tighter i believe.[/quote]
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
send ur rear shocks to hygear, u wont be disappointed.
