I have had some bad luck . My Trac has been hitting the clamps that holds the Y Pipe to the Turbo pipe. I have talked with Quite a few dealers and they have said that they have been having some problems with the clamps coming loose and turning and the trac has been catching then and in some cases damaging the titianim header. Some of the dealers have been contacting there customers to bring in there sleds and they have been tacking the clamps with a weld so they can not turn.It is not a easy or cheap job to change them. Just wanted every one to know to keep a eye on them and to keep the clamps tight.
thanks for the info... I had a problem with tha (as MCX X-press it) plate with lot's of holes under the turbo, that the track hit it, and took it away, and at the same time it smashed the suppert bracket....
