Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Now that’s quick!Just did the upper bushing, welded the tensioner, oil change and cut the barrels on the throttle body clamps. 4.5 hours
It took me more then that for just the TB barrels.
Erskin
- Feb 6, 2021
- Maine
- 2021 Thundercat
265 maxspool TD SM
- Bangor
Foolish question here but I haven't researched anything...is this a yamaha chaincase issue also or should I check mine on my tcat as well? Changed gears last year and all appeared to be good at around 4k but didn't focus on the tensioner
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Chain cases are the same.
Turboflash
- Mar 18, 2019
- Southern MN
Still hired. Right now I'm a little tired of working on these things. It was a busy summer in my garage. 4 complete engine rebuilds which involved: Remove engine from chassis, complete disassembly, get heads/cylinder blocks repaired, all new pistons rings, chains, gaskets, rod bolts, water pump rebuilds, check valve shim and adjust, engine reassembly, install in chassis. Search and fix boost leaks, chain cases. Studs, etc, etc.
So, I'd hire you in a minute and I'll just watch (with a couple beers). LOL
Maybe we'll get to ride eventually. NO snow here in southern MN. We had some but this week's thunderstorms melted it all.
Turboflash
- Mar 18, 2019
- Southern MN
Sidewinders and TCats are all "YamaCats." Cat builds both chassis, Yamaha supplies engines. Stickers, decals, and paint are different but the sleds are pretty much same except Sidewinders run Yamaha clutching; Cats run Cat clutching.Foolish question here but I haven't researched anything...is this a yamaha chaincase issue also or should I check mine on my tcat as well? Changed gears last year and all appeared to be good at around 4k but didn't focus on the tensioner
Erskin
- Feb 6, 2021
- Maine
- 2021 Thundercat
265 maxspool TD SM
- Bangor
Yes know all that but for some reason way back I thought I remember reading somewhere the yamahas had different clutches, chaincases and skis.. I know the design of the chaincase was the same just wasn't sure if yammi used their own gears and a different tensioner, thus the question regarding checking mine..Sidewinders and TCats are all "YamaCats." Cat builds both chassis, Yamaha supplies engines. Stickers, decals, and paint are different but the sleds are pretty much same except Sidewinders run Yamaha clutching; Cats run Cat clutching.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Another difference I believe is the jackshaft. Cat has a different jackshaft for the TEAM secondary.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
I just purchased an XF9000 and swapped the secondary shaft to Yamaha and have all Yamaha clutching on it now.Another difference I believe is the jackshaft. Cat has a different jackshaft for the TEAM secondary.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
"The chaincase's" are the same, the gearing is different within the chaincases for each brand.Yes know all that but for some reason way back I thought I remember reading somewhere the yamahas had different clutches, chaincases and skis.. I know the design of the chaincase was the same just wasn't sure if yammi used their own gears and a different tensioner, thus the question regarding checking mine..
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
My '17 was tight when I opened the cover up a few weeks back. Took them out and applied permatex (red) on them,to be safe.
Permatex red clearly better than loctite (red) based on a non-bias video by project farmer on YouTube.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
Not to hi-jack the thread but. What is ""CUTTING THE THROTTLE BODY BARRELS""? As a stock machine trail rider only, is this something I should be aware of?Just did the upper bushing, welded the tensioner, oil change and cut the barrels on the throttle body clamps. 4.5 hours
Fords4life
- Dec 7, 2021
- South Dakota
Check out the post throttle body boost leaks, this will answer your question, little spacers on clamps between throttle body and head.Not to hi-jack the thread but. What is ""CUTTING THE THROTTLE BODY BARRELS""? As a stock machine trail rider only, is this something I should be aware of?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Not if you are stock.Check out the post throttle body boost leaks, this will answer your question, little spacers on clamps between throttle body and he
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
The "barrels" are the spacers that limit how tight you can make the clamps on the throttle body and cylinder head boots. You cut them to allow for more clamping force in higher boost conditions.
Stock sled, no worries
vodoo child
- Oct 29, 2005
- Palmerton Pa.
Thank's guy's, I"m out for the season due to Covid pneumonia hitting my lungs so my seasonal maintenance has been put off for a while. I've been following the water pump issue posts, my sled has over 11K on it so i figure it's clutch rebuild time and I'll replace the water pump as well. I'm leaning towards Robby Gordon's kit since it's so complete. Thanks again and sorry to get off post!
- 8K
