Metallicat
Well, I decided that letting gas sit in my tank and carbs for 4 months is probably not the best idea. So I drained my gas tank, started it last night and ran it until it died, and then today I disconnected the carbs from the intake flange and drained the floats. I actually removed the float bowls to get all of the gas out and then took out the pilot jets just to see what everyone is talking about as far as how small the jet passages are. Yup, they are small!
So...I read on another topic that there is a pilot jet adjustment screw on the bottom of the carb towards the engine side.
If there is such a screw, I sure can't find it on my sled.
I thought that since I have access to the carbs now I would check all of the adjustments - is there really a pilot jet screw on these sleds????
BTW - it isn't such a bad job to get to the pilots and drain the floats. Will probably do this in the spring for summer storage to get all of the fuel out of the carbs. There is a drain plug on the bottom of the carbs that works pretty good.
