kurzy
- Mar 25, 2011
- Peterborough On, Can.
- '08 40th. Anniversary Nytro RTX
Just bought a 08 Nytro RTX 40th. An. I took it home to swap the track and found the center shock is burst below the adjustment threads. Is this a common problem? Iwas under the impression these things are built to launch. The replacements are very expensive, and the aftermarkets are worse. I weigh 175# and I hope I can make the stock ones work.
NFLD-Nytro
Your sled is four years old, and the problem with anything that "made to launch" is that people will launch them. Nothing can be pounded on forever without showing some wear.
It's a shame you didn't notice the problem before you bought it, cause you probably could've knocked enough off the price to pay for a new shock.
kurzy
- Mar 25, 2011
Fair enough, Ijust hope I can find something that will last. I'm no snow-crosser, I just want something that will take some agressive riding.
jp111
look around , there are several shock tuning centers on this website, in the little bit of searching I did I found that some of them had several used shocks at good prices. Or look at z-broz website they sell there own exit shocks and they are not terribly priced. Good luck to you.
kurzy
- Mar 25, 2011
Thanks for the help.
LJ 452
Get a Fox Zero Pro. $220 at Carver I think valved to your liking. It won't have the res. or rebound adjustment but I doubt you'll notice. If you decide latter on that you want to add a res. you can. In fact, talk to the shock house you choose, you may be able to use the stock res. just ditch the steel IFP.
TVBrian
- Mar 17, 2009
- Port Perry, Ontario
- www.portperrysnowmobileclub.com
If your gonna beat on the sled a bit, then I would suggest doing rebuilds ever couple seasons at least. I have a shock guy local to us that is really good.... If you want his info, give me a shout. He may have some replacement options for you too...
stock
Check classifieds on this site seen some 08 part outs lately. I have seen a xtx shock on a friends sled buldge out. Not sure how common it is .
nytroman20
I lost the banjo bolt that connects the line to the shock and the rebound doesn't click anymore. Also the bottom threads for the premise stripped... She's at the dealer now... Good thing I took the Y.E.S plan!!
kurzy
- Mar 25, 2011
If I can get a stock one and have it rebuilt/valved I will. There is a guy in Buckhorn- XLRacing that I was referred to. If not I did have my eye on that Fox zero-pro. It would be great if the res. could be retro-fit. Thanks for all the input, I'm new to the site and to 4-strokes and i appretiate the help. Seems like quite the community.
stopdropanroll
This is a very common issue with the RTX. The fix for this is a HyFlo hose, I personally have seen this issue multiple times on some RTX's I have worked on. HyGear can tell you all about it, the hose from the shock to the resi is too small and creates extremely high amounts of pressure in the main shock body, that results in blown banjo fittings, burst shock bodies, and un fixable damage. You could replace the shock with something like a Axis or Fox. I had HyGear add the larger hose to my buddies sled and no issues since.
09nytro
Will hygear just sell the hose I can do it myself
stopdropanroll
09nytro said:Will hygear just sell the hose I can do it myself
Shock needs to be machined to use the hose, also new oil and nitrogen.
09nytro
I got all the tools to do shock do them all the time didn't know shock needs to be machined , I guess i will just keep changing oil every year , Haven't had a problem yetstopdropanroll said:09nytro said:Will hygear just sell the hose I can do it myself
- 147K
