arteeex
The list below covers the most of what I’ve done to prepare my Nytro for this coming season. After I tore the sled apart one thing led to another and before I knew it, a little over 2-grand had been transformed in to sled parts, most of which was clearly unnecessary - according to my purchasing manager.
* A-arm bushings
* Powder coat rear suspension components
* Fully clip track
* Extrovert drivers
* Excel high-flow header
* Oil / filter
* Clean tunnel
* Replace loose rivets on tunnel and exhaust cover
* Replace slides
* Repair throttle heater
* Install tether switch
* Replace clutch side drive shaft bearing
* Replace drive shaft bolt
* Make and install stainless ski bolt bushings
* Replace 4 idler wheels
* Replace exhaust gaskets
* Ceramic coat header and flex joints
* Rebuild front shocks – upgrade to Float 2s
* Torsion spring spacers
* Simmons Gen 1 skis
Based on my experience with this tear-down, I suggest that anyone with 2500-miles or more on their sled dig in and check the clutch side drive shaft bearing, the bolt in the drive shaft (chain side) and exhaust gaskets. On my sled with 4600-miles the bearing was shot and the bolt going into the chain case side of the drive shaft was in two pieces. The exhaust gaskets between the flex joints and header were all but gone. I am replacing four idlers that are somewhat stiff to avoid downtime during the season. Loose rivets supporting a bracket on the exhaust shield under the seat and a few on the tunnel were replaced too. These loose rivets on the exhaust shield caused an annoying rattle/buzz at idle and when blipping the throttle. If you hear this, you know where to look first.
I went with the Float 2 rebuild thinking it was time to have the shocks serviced anyway. The report back from Fox was that even with 4600-miles on the shocks all the internals, seals and wipers were still in very good condition. So it seems, unless you’re looking to get more done or have an obvious problem, you can run the Floats substantially longer without rebuilding.
The powder and ceramic coatings (by Half Baked) was done to provide a little more life for the exhaust and to protect the corrosion prone bits under the sled. Really nice work by Half Baked too.
And, I’ll give a shout-out to Port Yamaha for their help, prices and prompt delivery – for which I will anticipate a large honorarium.
With a little more wrenching and a nice big dump of snow Angie and I will be ready to go.
* A-arm bushings
* Fully clip track
* Extrovert drivers
* Oil / filter
* Clean tunnel
* Replace slides
