arteeex
towerrigger said:I gotta ask you, How does your seat and exhaust plastic not melt with it covered right in. Will the ceramic coating cut the heat down that much?
P.S. I'll take 4 of those ski bushings. Made to length for a mountain ski. PM me for my address.
There's a 1/2" gap between the tunnel and the exhaust shield along it's length. Plus the header is still exposed near the front of the tunnel. My objective was is to reduce the amount of snow hitting the exhaust, vaporizing and then re-freezing on the tunnel. The shorter shield I used last year did a decent job of reducing the ice build-up. On the theory that bigger is better, I've increased the length and added the gap. I don't see heat being an issue as there's plenty of venting.
The ceramic coating is just to reduce the oxidation of the stainless and provide a little more life to the flex joints and header. Those pipes will still be hot.
Do the mountain skis use a different bushing set than the trail ski?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Do the mountain skis use a different bushing set than the trail ski?[/quote]
Yes...
Yes...
