yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
My nytro is draining the battery when driving and i get code: err 1 and 46.
I just barely got home on the last ride and had to turn off the lights to keep it running.
I have a lightweight battery that has worked perfectly a couple of years, can the battery have gone bad?
any input?
john
any input?
john
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
sounds more like a bad stator if it can't keep the battery charged.
yamahamm
- Oct 9, 2009
- Norway
Yeas but it is charging but maybe not enough, i have 13,8v when the sled is running. The strange thing is that it happened on a ride earlier also but then the engine was covered in snow due to a vent that was broken and i assumed it was water in a plug or something that f... up that time, then i have used the sled many times but only in daytime and with the lights off(its not legal to drive here in norway so i have a switch on the lights) both times the sled has died i had the lights on because it was late and dark.
Sportsterdanne
What kind of light weight battery ?
Try the stock battery.
yamahamm
- Oct 9, 2009
- Norway
I have this battery: http://www.atbatt.com/shorai-lfx21l6-bs12-lithium-iron-phosphate-lifepo4-powersports-battery.asp
Cant try the original because that one failed 2years ago so i don't have it.
Same thing today, worked fine all day but drained the battery, but i measured the battery before i drove today and i had only 12,6v when the sled was running so its not charging
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Check your voltage regulator first, the connections there can get corroded and it will not charge properly.
yamahamm
- Oct 9, 2009
- Norway
Wil do that
yamahamm
- Oct 9, 2009
- Norway
I checked the regulator and it was toast, luckily i had a new one so i put that on and everything is working great. Now i have 14,4v when the sled is runningCheck your voltage regulator first, the connections there can get corroded and it will not charge properly.
Thank you for the advise
yamahamm
- Oct 9, 2009
- Norway
And that saved the rest of my season, still a month or 2 with snow in the mountains
slushy but still fun to drive in
