ZR800EFI
Had the crank position sensor code being thrown.
Took the stator cover off to replace, and there is a bit of oil behind the cover. Enough to have a film all over the stator and sensor.
Should there be any oil behind there? I'm thinking not, but when I pulled the bolt out of the crank, a bit more oil came out (not a lot, but it did drip out), so I wonder just over the years if the oil has been dripping from there is normal.
Or is the crank seal done?
Thanks.
Thanks.
