JohnWI
So I forgot my manual before driving up north for my first oil change. I just read the manual and see I've neglected to drain the oil from the crankcase.
I thought there was one, but wasn't quite sure as there are a couple of hex-head screws/bolts in that area.
Did the filter, and oil reservoir.
For what it's worth, the rest of the job was pretty easy (at least with the help of a filter, band wrench). I'd say the next round will take about 30-45 minutes:
Fire it up to get things warm.
Take off side panel screws and remove panel.
Take off screws and remove the bottom cover.
Remove head plug, oil level plug, drain plug, filter, and oil pan drain plug.
Install plugs, filter, add oil, run for a few and check for leaks.
Reinstall side panel, add some blue loctite to the bottom cover screws.
Then loosen three screws for the air filter, tilt it out of place, remove the battery cover, the two leads and you're set to take out the battery for the season.
MadMax
You got 95% of the oil out... It will take just under 3 liters... About 3 quarts if you go with normal after market oils... MM.
JohnWI
Just wondering your thoughts about how much oil is left ONLY in the crankcase?
MadMax
Not much at all really..........................Just remember that allen head screw with the copper washer next time.....
Make sure you didn't over fill this time.. Like I said, if you do a "complete" change it takes 3 full liters.. You may have left 6-8oz.in the crank case.. If that.. MM.
Phantom
- Apr 2, 2004
Don't have the info right in front of me but I think I remember something like .3 qt. is in the crankcase.
