Oil filter loaction?
T-Bone
Western NY
Where is the oil filter located on the Nytros? Can you get at it from underneath the sleds access panel or from the top like the Apex? Just wondering if changing the filter and oil will be easier than the Apex.
It's at the bottom directly underneath the motor. You have to remove some plastic but it's really not that difficult.
remove the 2 bolts off the bottom of each side panel, remove 5 plastic push clips on the stock skid plate, remove the skid plate... viola, she right there. ski
Yep, just as has been described. The oil filter is really accessible.
Thanks , sounds alot easier than changing the filter on the Aex.
