jimmie d
Ordered, crazy as I entered this part number at the site and came back zilch.
Jim
Jim
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
RX1-M said:sleddersteve it is not a 51365 for wix ....
You're right, I was looking for one to fit my Rage.
Part Number: 51358
UPC Number: 765809513587
All Applications
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.420 2.230 0.150
51365
UPC Number: 765809513655
All Applications
Style: Spin-On Lube
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.577
By-Pass Valve Setting-PSI: 8-11
Gasket Diameters
Attached 2.475 2.173 0.233
impalapower
Anybody make a filter that holds a roll of toilet paper? They did this back in the days.
SledderSteve
- Apr 23, 2003
- Rental
An old sweat sock in a beer can held on by duct tape will work too.impalapower said:Anybody make a filter that holds a roll of toilet paper? They did this back in the days.
Gotta love duct tape, never hit the trail without it even if I do forget my tow rope.
Roadrunner
Can anybody tell me where to buy the K&N filters at a reasonable price ?
impalapower
SledderSteve, damn you're smooth. A duct tape tow rope, now thats thinkin'!
SledderSteve
- Apr 23, 2003
- Rental
Thanks Kevin,
Duct tape has gotten me and obviously others back home off the trail more times than I can count. I even used it once to close a big ol' gash in my leg that was quite a bit more than the "band-aids" in my little bitty first aid kit could handle.
If I couldn't carry anything else, I'd carry a fresh roll of duct tape and a Multi-Plier. I've found the Gerber brand to be my favorite http://www.gerberblades.com/products/results.php
Of course, being as acquainted with Mr. Murphy as I am, I do tend carry quite a bit more than that. :wink:
impalapower
SledderSteve, isn't that the Red Green show that uses duct tape for everything? If so you must have seen every episode! And yes, that do all pliers, I've heard those things are the ticket!
SledderSteve
- Apr 23, 2003
- Rental
That's correct, "If women don't find you handsome, they should at least find you handy."
I also look to Red for advice on what I need to carry with me on the trail. http://www.redgreen.com/images/scrapboo ... y_belt.jpg
impalapower
So Steve, now I know what you look like. Boone would be a better name!
SledderSteve
- Apr 23, 2003
- Rental
LOL, that would almost be preferable to the "handle" that got hung on me during a '97 snowmobile trip that I've never been able to shake. :wink:
2003red136
- Dec 1, 2005
wix 1358
the 1358 is definately not the same filter. I checked one with the OEM yammie and a 1/2 deep socket fits in the wix but wont go into the yamaha so be very careful. I will be using yamaha filter til someone makes one closer than a 1358! :ORC
Red2003
The NAPA 1358 works just fine.
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Do you have to use Yamahas filter and oil if sled is still under warranty.
grumpysanta
yes i use the hiflo for my bikes and sleds , worked well for years
- 14K
