kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
stevewithOCD said:A manufacturer can not "not warranty" a vehicle if you use a different brand oil. It is against the law. As long as the oil used met the minimum requirements. As kviper said there is nothing wrong with Yamalube, but Amsoil is one of the most trusted names in the business so why not pay less for more. If Yamalube was cheaper or closer i would probably buy it... Actually i run 0w-30 full synthetic so Yamalube is out for me...
I have heard that they can't deny warranty and I have also heard argument's. Not worth it to me!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Yamalube for me in all 4 sleds.
Daranello
Suspended
Yamalube 0w30 semi syn....
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
Daranello said:Yamalube 0w30 semi syn....
Me too
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
kviper said:stevewithOCD said:A manufacturer can not "not warranty" a vehicle if you use a different brand oil. It is against the law. As long as the oil used met the minimum requirements. As kviper said there is nothing wrong with Yamalube, but Amsoil is one of the most trusted names in the business so why not pay less for more. If Yamalube was cheaper or closer i would probably buy it... Actually i run 0w-30 full synthetic so Yamalube is out for me...
They want you to believe your warranty will be null and void but this simply isn't true!
As long as the oil you're using meets the specs and requirements then they cannot deny a warranty claim. (Google it)
Lots of info on bistog.com about Yamalube.
If you don't mind paying triple the price for a less than stellar oil, then carry on as it makes no difference to me, but for those who do care, just type in yamalube uoa in the search section and see for yourself.
Last info I am going to post.
Cheers
http://www.bobistheoilguy.com/forums/ub ... ost2049316
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Well said Irv. Again, I have no problems with Yamalube, but in MY situation I pay less for better closer. That's why my opinion was "whatever is easiest". If I didn't have an Amsoil dealer down the street then my vote would be Mobil 0w-30 @ K-mart.
mcamzr
Is there a reason why not a lot of you use the 0w40?
stevieu1
my dealer sells yamalube for $8/qt,never had a prob,no reason to switch.I'll stick with it.
09nytro
Amsoil for me
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
mcamzr said:Is there a reason why not a lot of you use the 0w40?
Easier starting in cold temps! Quicker oil pressure to bearings in cold temps! Not as thin when the motor is hot! Works for me.
Amsoil 0-40!
Sasquatch said:mcamzr said:Is there a reason why not a lot of you use the 0w40?
Amsoil 0-40!
Yes sir good stuff and good reasons for using it.
sx7001
- Jun 28, 2003
- Sidewinder
Grimm said:I will vote for Yamalube full synthetic if price was no object, but at $20/qt, I don't buy it as I feel Yamaha is overcharging us for it.
I personally use AMSOIL full synthetic.
Yamaha is not overcharging, your dealer is!! I pay $14.95 a liter for Yamalube full syn here.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
You guys need to understand that Yamaha puts a msrp on the price on parts I know of a lot of dealer who will add 20 o/o to that price but with the net they are getting caught . When I worked for a floor plan company I seen this all the time with oil an other fast moving parts. So it is best always to shop around an find a dealer who thing long term not short term.
Nick1945
stevieu1 said:my dealer sells yamalube for $8/qt,never had a prob,no reason to switch.I'll stick with it.![]()
I get mine by the 12 quart case, and it's a little over $6.00 a quart, never had any problems.
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
SAE 0W-30:
Castrol SYNTEC 0W-30 European Formula is engineered to meet the Mercedes Benz 229.5 specification. The 0W-30 viscosity grade is ideal for winter conditions where low temperature pumpability is required. A unique, low-temperature formulation provides exceptional pumpability in cold weather and allows for unaided engine starts down to -40°F. Exceeds all car and light truck manufacturer's warranty requirements for the protection of gasoline, diesel and turbocharged engines where API SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A3, B3, B4; VW 502 00, 505 00, 503 01; MB 229.1, 229.3, 229.5; BMW LL-01; GM-LL-A-025, GM-LL-B-025 and the engine protection requirements of ILSAC GF-3 for API Certified Gasoline Engine Oils.
Has no Energy Conserving Standards...less then $10 a litre Canadian at Wally World.
