ski332
- Nov 17, 2022
- saskatchewan
- 2013 venture
I have a 2013 venture that had a bad starter So replaced it and change oil Now i got a lot of oil pouring thru the hose tha comes from oil
reservior to top of air box Oil is on L level on stick when screwed in Any ideas???
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
To check the oil, you don't screw it in. You unscrew it out, wipe it, re-insert it WITHOUT screwing it resting on top of the threads, pull it back out and read level.
If you have oil coming out of the tank vent hose, you probably had it on its side and the oil accumulated in the hose. Some probably stayed in it when righted so it got pushed into the airbox when started.
ski332
- Nov 17, 2022
- saskatchewan
- 2013 venture
Oil was drained before starter change.
The machine was never laid on its side The amount of oil that came out on 2 serperate
starts was over a liter
When i changed oilI put 1 liter in head and 2 in oil reservoir
kinda stumped
kinda stumped
