Fast
- Sep 25, 2018
Dealer said not to drain the oil lines when doing a oil change they had 1 oil pump fail from a air lock said the motor needs that little bit of oil to ensure it will pump oil on initial start
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
ALWAYS listen the dealerDealer said not to drain the oil lines when doing a oil change they had 1 oil pump fail from a air lock said the motor needs that little bit of oil to ensure it will pump oil on initial start
Just hit kill switch and turn it over awhile before starting then. Even after removing the hoses there is still quite a bit of oil held in sidecover. I would say about a cup full when I had mine off.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
I have been draining the oil lines on my Apex's for 13 years with no problem's to any of my ENGINE'S . approx 47,000 miles.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
When i built a new Apex engine, oil pump needed priming. And it was simple and fast. An engine with oil in it already, and in the pump already will never have issues due to draining piping. That dealer really needs to think abit deeper IMO.
Same dealer that sold you the oil warranty cash grab and says semi synth oil is best? lol
Dan
Dan
Fast
- Sep 25, 2018
dealer never sold me a warranty no cash grab here its all coming from yamaha trying to sell there oil , he's telling me they had 1 failure due too draining hoses and creating an air lock doesn't matter if oil is still in the pump once the air goes though it wont pump anymore not agreeing with it i'm just relaying the information , there was a post earlier about hitting the kill button and rolling it over could even fill the hose back up with clean oil after draining it then roll it over with kill button onWhen i built a new Apex engine, oil pump needed priming. And it was simple and fast. An engine with oil in it already, and in the pump already will never have issues due to draining piping. That dealer really needs to think abit deeper IMO.
Dan
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I never drain hoses The oil filter does its job! We’re talking one cup of oil here? Lol
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I think it's easier to flush out with plain oil, drain & re-fill. Costs me $9.00.
It sorta rinses out the motor & flushes out those hoses anyways.
All my hoses are sealed with a sealant so i don't want to break the seals.
TO EACH THEIR OWN
TO EACH THEIR OWN
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Actually all oil filters only work at idle or slightly above.
Plus the filter does not remove water or gases that work their way in there.
BUT, i agree 1 cup of oil does not mean we need to sweat or lose sleep........................................................................................unless you have OCD!
Arc21981
- Jan 31, 2019
- Portland,Maine
- 2018 Sidewinder xtx se 137"
So with this theory I wonder how you fill the oil filter 100% and install sideways on motor so there is no air in the filter, if dealer thinks any air in lines will cause pump to not pump.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
No worries! I’m thinking horse tranquilizers! It all good. That’s a inside UP joke folks eh!Actually all oil filters only work at idle or slightly above.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
More rumors....
Just change your oil like the manual says.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I drain oil from hoses because I remove the cover with the tank on and service the chain case. Never have had an issue building oil pressure plus I like getting it all out of there too. You should have seen the crap inside the tank when I resealed it the first time too! Shavings and silicone debris from assembly galore. Glad I split the oil tank the first time.
Fast
- Sep 25, 2018
Mike do you use silicone on the chain case when reinstalling it?I drain oil from hoses because I remove the cover with the tank on and service the chain case. Never have had an issue building oil pressure plus I like getting it all out of there too. You should have seen the crap inside the tank when I resealed it the first time too! Shavings and silicone debris from assembly galore. Glad I split the oil tank the first time.
KnappAttack
- Feb 19, 2004
- Welch MN
Not on the chain case, but I used Ultra Black on the oil tank seal.
- 7K
