yellow rider
- Aug 4, 2014
- yamaha
I changed oil in the spring. Went to start this week, checked the oil level and it was empty. Pulled the drain plug from the block and all the oil was there. Refilled the reservoir and started motor. Looked into tank to be sure oil was circulating, everything looked good. I checked the parts fish and it doesn't list a check valve anywhere in the oil system. Has anybody had this happen before? Any ideas on what is going on here? Can damage occur with all the oil in the bottom of the motor?
