zquick1
Does anybody know what the story is on these kits from ulmer racing? My front end is loose and dont want to waste anymore money on the stock junk bushings .Or is there another place that sells these kits?
garyw
bushings
Had the oilite bushing kit in my apex and now I have the kit in my nytro.really tightened up the front end.Money well spent.Have 5100 miles on my 09 nytro and had 6000 on the apex and the bushing show NO signs of wear.
09nytro
It is a nice kit and pioneer also sells a kit
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The FX Nytro bushing kits are in stock. Just call and place an order. 605-387-2833
zquick1
sweet thanks
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
About how long does it take install the kit? Have ulmers kit for 08 nytro rtx
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
sooo worth it!
I just installed these on my Apex. Tolerances are extremely tight, which can make them a bit tricky to install, but take out all the sloppiness out of the front end. It took less than an hour to install, and the difference was immediate. Add up the cost of the OEM plastic junk and compare it with the Ulmers kit... its a no brainer!
Blu2U2
On Pioneer & Ulmer's web sites these are "sold out"???
AttakDog
Ulmer has them, just got them and put in my Nytro. $90 worth every penny
Blu2U2
AttackDog, thanks for the remark. I just called Ulmer's and they are closed until Monday.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
That is where I got mine from, he probably is too busy to change the web site. And probably as soon as he gets them in, he is sold out already. Haha
XTX Kory
Oredred mine on Tuesday and got them yesterday. Any tips or tricks for installing them? Thanks
AttakDog
Take all the front panels off, remove all the front suspension ( I left the ski and lower ball joint together). The uppers use 1 long bolt with no nut 2 bushings on each, the lowers are separate nuts and bolts 4 bushings on each. They are all the same. Make sure you polish the inside of the a-arms good before you push the bushings in. Also polish the inner sleeves that the bushings ride on. It is a very tight fit. A little grease helps too.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Just installed my upper arm bushings (ulmers). Wow what a difference in the ride and handling, really tightened everything up. And I only did the uppers and need ball joints too. A tip for inserting the bushings in the arms. I used a foot long 1/2 inch threaded rod, thick washers and a nut on each side. Put it right through the arm and do one side at a time. Worked really well and everything goes on straight and don't have to worry about breaking those thin flanges off. Its very controllable and they slide right in with ease. Hope this helps some guys out.
Blu2U2
Allen called me today and he will be sending them out tomorrow. Very happy with Allen's reply & follow-up for being off for a couple of days to ride!
