Old MPI apex supercharger fitment
attak 06
Deer Lake, NL
Canada
2011 Apex XTX
I have a chance to purchase a used MPI supercharger from a 2006 Apex mountain that was originally purchased in 2008. I'm trying to find out if this kit would work on my 2011 Apex XTX. If so, wat other parts would I need to buy, along with gaskets and a thicker head shim to rum pump gas? Thanks
Give Matt a call at mpi. He could set you up. Any issues in the install call ulmer for clutching BOV, etc
Yep, and as far as ulmer he might be hard to get a hold of. So mail, and call him. He is working on my buddies sled, and the tractors for tractor pulls also. So can be busy summer and winter. Just depends on time of year
Perfect. Thanks
Did the older kit fit on the newer sled?
You
Pretty sure all u need is the fuel controller settings and or run power commander. Call Matt at MPI or Allen at Ulmer Racing.
Different fuel controller use on the 11+ apex. Everything else is the same.
I haven't installed yet, had a couple missing brackets had to track down. Just waiting on head studs now. So, hopefully by end of next month I should be ready to install.
I have the Gems controller. What controller would I need and where can I get it? Thanks
K. Is this an updated Gems controller? Would I now need new sea level settings for the new one or could I start with the settings of the old one?
Yes. Its set up for sea level.
Probably a stupid question.. Lol. Are you able to update my Gems Controller instead of buying a new one. Won't know if I don't ask. Lol
