dirk
Well I opened my chaincase and cleaned everything as well as re packed/replaced some bearings but now the sled won't go into reverse? I suspect it's the lever inside but just curious how to put the cover back on correctly so it's in the proper position. I didn't touch the linkage adjustment.
Kirkdking
When sliding the cover on got to hold the handle up almost all the way and as soon as it starts going in slide the handle to 3/4 or 1/2 the reverse fork got to grab the outer ring of the bottom gear. It's tricky first time after a few times its a piece of cake just some fooling around
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Kirkdking said:When sliding the cover on got to hold the handle up almost all the way and as soon as it starts going in slide the handle to 3/4 or 1/2 the reverse fork got to grab the outer ring of the bottom gear. It's tricky first time after a few times its a piece of cake just some fooling around
X2
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
You'll have to pull the cover off and when you put it back on you need to ensure the reverse fork is pointing up. You actually need to watch/manipulate the fork to drop into the groove when pushing the cover on. If the cover has any resistance or bounce when you mate the halves then it's not mated properly. You'll only do this once. lol
dirk
Ok great, I'm getting good at this! It'll be the 8th time I've had it off and on in the last 2hrs.
canoehead
- Jan 14, 2011
- NE, Alberta
Kirkdking types faster than me....
Kirkdking
canoehead said:Kirkdking types faster than me....
Can do this in my sleep in the last 2 years have had mine off 20 times lol
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
I've also noticed if I have the chain tension too tight it won't go into reverse.
Kirkdking
revster said:I've also noticed if I have the chain tension too tight it won't go into reverse.
Finger tight then quarter backed off works wonuderfull...
dirk
Yep I did finger tight, I'll try backing it off before I remove the cover again tonight. I did lift the linkage rod as I put the case back on (I removed the top linkage when taking the cover off so I had to lift it back up to that height to reinstall the cover because I couldn't lift it afterward).
canoehead
- Jan 14, 2011
- NE, Alberta
If it worked prior to removing the cover it's your fork. You can watch it go on as you sneak the top of the cover on. Start with the bottom first.
revster
- Aug 18, 2004
- La Salle MB
Kirkdking said:revster said:I've also noticed if I have the chain tension too tight it won't go into reverse.
Yes but finger tight for you and finger tight for someone else might not be the same. A lot of times mine won't go into reverse 1/4 off so I back it off slightly more and it will go in.
dirk
Well I got it and that was probably the most frustrating thing I've ever had to do in recent years. I don't know what I was doing wrong but after 2hrs of taking it off and on I'm done.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Yup, that's how it's done. The next time it will be easier.
dirk
I sure hope so! I was ready to burn the sled to the ground lastnight!
Thanks for the help guys!
