Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
- Yamaha nypex mcx 400
Hello. I have changed to a bigger turbo and went with a external wastegate on my project. But sled is overboosting now on my 23 psi race flash with same crack pressure. I asume the boost duty cycle in boost table gonna be different with another turbo and wastegate. Can I compensate this with a softer spring in wastegate to get pressure down to 23 psi? Will the boost duty cycles be more correct then all over the boost map?
Also have a function in app called Boost WGV duty multiplier. Can someone tell me exact what this function is?
Thanks.
Thanks.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Thanks.
What is the waste gate duty cycle multiplier set at on the app? Try lowering it if its set high, also what is the boost + or - set at? Otherwise you'll have no choice but to lower the wastegate spring. What's the crack pressure now?
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
The multiplier is set to 100. But what does this function do? If I put 90 there will it pull 10% duty cycle all over the boost table?
Boost is not adjusted in app. Wastegate have a 14 psi spring, same as the internal wg in the turbo tech kit. Crack pressure is arround 11-12.
KnappAttack
- Feb 19, 2004
- Welch MN
Drop the multiplier to zero and work up from there. You might end up say at 50-70% to hit your number.
You can drop the boost to say -2 in app from target too depending on how much you are over boosting. Playing with the boost and WGV duty multiplier should get you in the window.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Droppet it to 60% and is spot on! Thanks
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Can someone tell me exactly what the ‘boost WGV duty multiplier’ does in the fine tuning options? Does it lower the boost duty cycles all over the boost table? In the hole rpm register?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Call your Tuner.Can someone tell me exactly what the ‘boost WGV duty multiplier’ does in the fine tuning options? Does it lower the boost duty cycles all over the boost table? In the hole rpm register?
